Jan 4, 2008 - 4:54 PM
Enthusiast ![]() ![]() ![]() Joined May 19, '06 From North NJ Currently Offline Reputation: 16 (100%) |
is it possible to fit 18" rims on our cars? anyone that has 18" rims on your car how is the ride?
Jan 4, 2008 - 5:05 PM
C'mawwwn Twitch! You should know this already!
I have 18's, and I have Tein SS coilovers and I don't rub or have any issues. This post has been edited by Supersprynt: Jan 4, 2008 - 5:43 PM -------------------- |
Jan 4, 2008 - 5:09 PM
Enthusiast ![]() ![]() ![]() Joined Nov 22, '05 From Mesquite, Texas Currently Offline Reputation: 0 (50%) |
QUOTE(twitchh17 @ Jan 4, 2008 - 4:54 PM) [snapback]628199[/snapback] is it possible to fit 18" rims on our cars? anyone that has 18" rims on your car how is the ride? It is possible to install and drive with 18" rims. I have 18" rims with a 2" drop, and the only problems that i have undergone is slight rubbing during COMPLETE revolutions of the steering wheel. |
Jan 4, 2008 - 10:45 PM
Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
QUOTE It is possible to install and drive with 18" rims. I have 18" rims with a 2" drop, and the only problems that i have undergone is slight rubbing during COMPLETE revolutions of the steering wheel. What tire size are you running? Recommended size is 15/35/R18, but i've also heard that 225/40/R18 doesn't have any rubbing issues. My sig. shows the recommended tire size on 18's. This post has been edited by netrata: Jan 4, 2008 - 10:47 PM -------------------- ![]() |
Jan 5, 2008 - 3:32 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Dont get 35 tyres, get 40 sidewall tyres. Better comfort and better handling.
-------------------- JDM Powerplant installed, BPU coming very soon!
Jan 5, 2008 - 9:46 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
235's will also fit without a problem, might as well take advantage of having an 8" wide wheel instead of a 7.5 in wheel where it counts with the rubber. im down about 2" on my 18's and no rubbing or anything underdriving, when parked at full turning lock with the wheels they rub a little bit, but nothing serious.
watch out for potholes... the lips of 18's dont like low profiles and potholes -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Jan 5, 2008 - 11:28 AM
QUOTE(Supersprynt @ Jan 4, 2008 - 5:05 PM) [snapback]628202[/snapback] C'mawwwn Twitch! You should know this already! I have 18's, and I have Tein SS coilovers and I don't rub or have any issues. these are the rims thatll be going on, thoughts and opinions appreciated :] ![]() ![]() photoshop preview
This post has been edited by twitchh17: Jan 5, 2008 - 11:32 AM |
Jan 5, 2008 - 11:53 AM
R is radial, if you can go with a 235-245/40/18
40 is a percentage of the first # so the wider the tire with the same sidewall percentage, the better its going to ride like tony stewart says in them pontiac commercials with the alaskans... wider is better! take em to a tire shop and they should let you test fit different tires for free, go as big as you can with too much rubbing under normal conditions, un lowered shouldnt be too bad also be prepared to feel like you lost 20hp with these wheels -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
Jan 5, 2008 - 11:57 AM
lol its fine its not that fast of a car but she treats me well, yesssir. how much should it cost to install the rims and tires?
so 235/40/18 it is? This post has been edited by twitchh17: Jan 5, 2008 - 12:10 PM |
Jan 5, 2008 - 12:30 PM
235 wont fit unless its 8+J wide tyre. If its 7.5J wide 225 is max. Also check if the offset (ET value) is correct, should be lower then 40. Anything above 40 and the wheel will go to much into the wheel well.
Get one wheel onto your car and see how its fits. If its to much tucked in (as in to high offset) then dont go for it. It doesn't look good and you surely get rubbing issues on the inside. So get the info about the offset before searching for tyres and all. And just a thought. I like my 18" wheels for looks, but I dont like them for driveability, I'm planning to switch to 17" again. Want more rubber (8J compared to 7.5J now) and driveability back. This post has been edited by Kadett: Jan 5, 2008 - 1:17 PM -------------------- JDM Powerplant installed, BPU coming very soon!
| Lo-Fi Version | Time is now: August 31st, 2026 - 2:23 AM |
