> worn piston rings
post Jan 5, 2008 - 2:29 PM
bosence_motors1
Joined Jan 2, '08
From cornwall
does anyone know if piston rings on a 1.8 celica(1996) can be done with the bottom end in place in engine bay?
post Jan 5, 2008 - 3:19 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
this should be in the engine section.....
BANNED. for life, you moron.
post Jan 5, 2008 - 3:39 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
well anything is possible, however it would most likely be more efficient for you to just buy a lower millage 7afe engine and put that in. if your rings are worn enough to need replacing, im sure other things are wearing as well.
post Jan 5, 2008 - 4:45 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i did a prelude like that. put it up on a lift. dropped the cross member, and oil pan. took off the head, then we undid the rod end caps and pooped the pistons out the top without touching the crank, just rotating it. was actually pretty simple like that. if you have access to a real lift.
post Jan 5, 2008 - 5:25 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i just got doing the same thing on my 5s
Lo-Fi Version Time is now: September 12th, 2026 - 3:48 AM
