> 7afe header, anyone know anything about this header?
post Jan 8, 2008 - 4:18 AM
dagreat1
Joined Mar 27, '06
From Gainesville
Is this a good buy if i have stock headers for my st?
http://cgi.ebay.com/ebaymotors/Toyota-Celi...1QQcmdZViewItem
post Jan 8, 2008 - 5:16 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
search around dude, its the common ''ebay header''
but to answer your question, yes its a good buy. sounds awesome too wink.gif
post Jan 8, 2008 - 5:32 AM
dagreat1
Joined Mar 27, '06
From Gainesville
lol thanks...
post Jan 8, 2008 - 12:03 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
But is it crappy? Like, a cheapo product? I need to replace the gasket on my header, and I'm guessing once I get the thing off, the whole thing will need replacing.
post Jan 8, 2008 - 1:30 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
you always get what you pay for, but it will last
its not a $3000 header, but it works just fine
post Jan 8, 2008 - 1:48 PM
GriffGirl
Joined Feb 7, '07
Sweet
post Jan 8, 2008 - 9:14 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
gives a nice pull above 3500 rpm till redline, sounds good, well made, cheap. you should wrap it or get it ceramic coated however since it just lets out sooo much heat.
post Jan 8, 2008 - 9:37 PM
pabel89
Joined Sep 28, '07
From new jersey
dont buy it dnt do the same mistake i did i bought the same header...this the problem the header brings the 02 sensor but the flex pipe doesnt ur gonna have to custom make one like i did its better if u buy the more expensive one they have on ebay tht one has for both 02 sensor...if u didnt kno are exhaust system has 2 o2 sensors. and if u leave one of ur check engine lights oing to come up.
This post has been edited by pabel89: Jan 8, 2008 - 9:40 PM
post Jan 9, 2008 - 2:34 AM
dagreat1
Joined Mar 27, '06
From Gainesville
thanks for the tip
post Jan 9, 2008 - 2:55 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
im pretty sure it only has one O2 sensor.....and the header is a little short because they are made for a corolla not the celica....you can get the flex pipe welded on at a local shop for about 30 dollars.
post Jan 9, 2008 - 5:11 PM
you need a flange for your second 02 sensor and have the b pipe extended about 6"-8".
post Jan 9, 2008 - 7:01 PM
pabel89
Joined Sep 28, '07
From new jersey
i bought the same header are stock header has an o2 sensor in the front then thier another one on the flex pipe...the ebay header only has 1 o2 sensor and its just on the header not one the flex pipe...what i did was went to an exhaust shop and they cut of tht lil piece from my stock flex pipe with the o2 sensor and weld it on to the ebay flex pipe...also the header doesnt reach all the way to the cat so what i did was buy a 93 ford probe cat which is longer...but tht was just me now i cnt pass state emmision i hvae to pay for it now but its worth it its onli $95 every 2 or 3 years.
post Jan 13, 2008 - 2:19 AM
CAMAricer
Joined Jul 25, '07
From San Francisco
If you buy the ebay headers, to solve the O2 sensor problem, just purchase a post-cat 02 sensor for a 95 ST. They fit perfectly as a pre-cat O2 for these headers. Only problem I had was finding those damn self-locking nuts to secure it (eventually went to a Toyota dealer to get them b/c Home Depot/Ace Hardware don't have them).
Umm...the exact item I purchased was a Bosch Universal O2 sensor, product number is 12210 at Autozone.
QUOTE(pabel89 @ Jan 9, 2008 - 7:01 PM) [snapback]629641[/snapback]
This post has been edited by CAMAricer: Jan 13, 2008 - 2:20 AM
2002 SC430 (WC) - 19" SSR Comp-H, Daizen swaybars, Sparco Demons, JDM Soarer conversion, carbon fiber spoiler, Injen intake, front strut bar, drilled/slotted Brembo rotors
1997 Celica ST (DD) - 17" ADR, ViS Zyclone CF hood, ViS CF hatch, K&N intake, Invader body kit
post Jan 13, 2008 - 11:37 AM
Bitter
Joined Mar 11, '06
there are 2 versions of the same header on ebay. one is setup for a flange type primary O2 sensor and the other for a screw type primary O2 sensor. look at your car and look at the product before ordering!
post Feb 16, 2008 - 9:39 PM
Bitter
Joined Mar 11, '06
speaking of the ebay header, i found the supplier in china that actually makes them.
http://exhaustmanifold.en.alibaba.com/
Lo-Fi Version Time is now: September 15th, 2026 - 12:12 PM
