> Complete List of TRD USA Parts
post Jan 14, 2008 - 9:05 PM
azian_advanced
Joined Apr 18, '05
From Calgary
hey guys and girls, i've compiled a complete list of TRD parts for the 6th gen. If there are any that i've missed or any information i should add, feel free to post them or let me know and I will put them up..
Important: All parts listed were recognized through the U.S. ToyotaWorld.com parts search engine and the following prices are in USD.
So these are the North American version part numbers of TRD Parts. Japanese TRD part numbers can be found at the link I provided at the end of this post.
Other genuine toyota parts sites are: Toyota Parts Cheap.com and 1st Toyota Parts.com if you want to compare prices.
Note: All parts have been identified correctly but have unconfirmed availability, so I'd suggest to verify with the parts dept before placing an order online.
more TRD parts can also be found from Valo666's thread (TRD Parts and #s)
1. TRD Front Strut Brace
BRACE ASSY,STRUT TOW
00602-53607-006
$223.84
^image taken from the TRD USA 2000 model catalog
Note: THIS ITEM IS DISCONTINUED
2. TRD QuickShift Kit
Version 1
QUICKSHIFTER 94-97
00602-30301-004
$154.89
Version 2
SHIFTER QUICK KIT
PTR04-20940-04
$166.44
Note: Not sure what the difference is between the two, but one of them will shorten the throw by 40% from stock.
3. TRD Lowering Springs
Version 1
SPRING SET,LOWERING,
00602-48130-008
$196.34
Version 2
SPRINGS LOWERING SET
PTR04-20940-08
$201.40
Note: Not sure what the difference is between the two.
4. TRD Performance Brake Pads
HP (High Performance)
1994-1997 Celica with 4 wheel disc brakes (ie. GT and GT-S)
BRAKE PADS (Front)
00602-04491-015
$50.68
1994-1996 Celica with rear brake drums (ie. ST)
BRAKE PAD SET,FRONT,
00602-04491-019
$51.33
HPZ (High Performance Z-Rated) (only available for ST)
BRAKE PADS (Front)
00602-04491-020
$80.17
Note: I'm assuming the 'Z' in HPZ is of a higher performance model? It sucks how it's only available for ST
5. TRD High Flow Air Filter
Version 1
AIR FILTER
00602-17801-001
$47.87
Version 2
FILTER AIR 3.0 V6 (don't be fooled by the '3.0 V6'. this filter is used in other models too.)
PTR05-06990-01
$49.40
CLEANING KIT AIR FIL (optional)
PTR05-00000-CL
$16.72
6. TRD Type-N High Pressure Radiator Cap
CAP RADIATOR 18.5PSI (or 127.55 kPa or 1.3 kg/cm)
PTR04-00000-03
$29.30
7. TRD High Performance Oil Filter
Version 1 (Red)
TRD OIL FILTER
00642-90915-002
$18.48
Version 2 (White)
FILTER OIL
PTR14-00000-05
$11.40
Version 3 (Black)
PTR43-00080
$9.95
Note: VERSIONS 1 & 2 ARE DISCONTINUED Version 3 still available. I just ordered 4 last week (May 11, 2011). smile.gif
8. TRD Oil Filler Cap
Version 1
CAP, OIL FILLER
00602-12108-001
$44.11
Version 2 (shown above)
OIL CAP,SCREW-ON BIL
00602-12108-002
$40.28
9. TRD Gear Shift Knob
A.
SHIFT KNOB BLK ALUM
00602-36303-005
$33.43
B.
SHIFT KNOB SILV ALUM
00602-36303-003
$33.43
C.
KNOB, SHIFT, LEATHER
00602-36303-001
$22.00
D.
KNOB SHIFT BALL TYPE
PTR04-00000-06
$22.04
E.
KNOB SHIFT LEATHER
PTR04-00000-05
$58.07
F.
TRD TACOMA SHIFT KNB
PTR26-35060
$36.00
Note: IIRC, D is the only one that is a direct install to the stock shifter. The rest may require modifications to fit.
10. TRD Clutch Kit
For AT200 Celica (ST Models) only
CLUTCH SET, HI-PERF
00643-31200-006
$304.70
This post has been edited by azian_advanced: May 20, 2011 - 10:03 AM
- azian_advanced   Complete List of TRD USA Parts   Jan 14, 2008 - 9:05 PM
- - azian_advanced   11. TRD 3S-GTE Metal Head Gasket GASKET CYL-HEA...   Jan 14, 2008 - 9:15 PM
- - D_Dawg   very nice, i thought u were messing with us with t...   Jan 14, 2008 - 9:30 PM
- - 95st-celica   wow thats awesome...someone needs to find that oth...   Jan 14, 2008 - 10:48 PM
- - CelicaST_CALI   YES YES,is that oil cap for the ST?   Jan 14, 2008 - 10:56 PM
|- - azian_advanced   QUOTE(CelicaST_CALI @ Jan 14, 2008 - 9...   Jan 14, 2008 - 11:16 PM
- - 808celica   i really want that front strut bar. and damn trd f...   Jan 14, 2008 - 11:09 PM
- - CelicaST_CALI   wat about that oil filter and strut bar??   Jan 14, 2008 - 11:24 PM
|- - laff09   QUOTE(CelicaST_CALI @ Jan 14, 2008 - 11...   Jan 14, 2008 - 11:38 PM
- - CelicaST_CALI   sickkkkkkkkk,ima admit i got a lil man crush here ...   Jan 14, 2008 - 11:50 PM
- - Rusty   nice TRD oil filter (JDM ones look different)   Jan 15, 2008 - 2:12 AM
|- - laff09   How come?   Jan 15, 2008 - 11:36 AM
- - daazndood   wow 200 dollars for TRD lowering springs. thats pr...   Jan 15, 2008 - 3:29 AM
|- - SAE-HI   QUOTE (daazndood @ Jan 15, 2008 - 3...   Feb 3, 2012 - 5:49 PM
- - Starcraftjunkie   So which quickshifter is the one we want?   Jan 15, 2008 - 11:29 PM
- - CelicaST_CALI   u dont even play starcraft....   Jan 16, 2008 - 12:00 AM
|- - Starcraftjunkie   lol.. nice way to go off topic. I did play. Way...   Jan 16, 2008 - 7:12 PM
|- - hongkongnerdboy   QUOTE(Starcraftjunkie @ Jan 16, 2008 - 7...   Jan 18, 2008 - 12:55 AM
- - azian_advanced   probably the later version... i've read before...   Jan 16, 2008 - 12:33 AM
- - Rusty   QUOTE wow thats awesome...someone needs to find th...   Jan 16, 2008 - 1:48 AM
- - kloudkicka   wow, you found alot of trd goodies, wish i had the...   Jan 16, 2008 - 7:33 PM
- - CaliJeff   i thought they dont make the 3 pt strut bar anymor...   Jan 17, 2008 - 9:47 PM
- - azian_advanced   yeah.. the part numbers that begin with PTR are th...   Jan 17, 2008 - 10:37 PM
- - Daftboy   tomo i will try too order the 3 point strut brace....   Jan 18, 2008 - 12:48 AM
- - azian_advanced   hey now don't make him have to change his name...   Jan 18, 2008 - 7:31 AM
- - Valo666   nice write up...i actually ordered some parts from...   Jan 18, 2008 - 12:24 PM
|- - laff09   QUOTE(Valo666 @ Jan 18, 2008 - 12:24...   Jan 18, 2008 - 1:23 PM
- - Rusty   oh stink to be where you guys are. We have overnig...   Jan 18, 2008 - 1:38 PM
- - vile_v   well today i looked up some trd parts on the toyot...   Jan 18, 2008 - 10:39 PM
- - Blurr05   Would anyone recommend a TRD Quickshifter kit over...   Jan 20, 2008 - 10:52 AM
- - Insanity-74   TRD Limited slip dif is still available Also the ...   Jan 20, 2008 - 2:18 PM
- - Valo666   QUOTE(Blurr05 @ Jan 20, 2008 - 10:52...   Jan 21, 2008 - 12:15 AM
- - Blurr05   So the "lever" on the TRD peice would be...   Jan 21, 2008 - 12:44 AM
- - _mikeE   i'm gonna go to the toyota dealership and see ...   Feb 12, 2008 - 6:41 PM
- - Tigawoods   great post. i might get some make some orders this...   Feb 12, 2008 - 11:11 PM
- - MaskedMan   Has anybody confirmed if the TRD part number for t...   Feb 12, 2008 - 11:38 PM
- - Tigawoods   i will check tommorow...haha nah im too lazy   Feb 13, 2008 - 12:43 AM
- - MaskedMan   I should have got up went walked 100ft and asked t...   Feb 13, 2008 - 1:54 AM
- - azian_advanced   you guys are so lazy.. haha, just call them and a...   Feb 13, 2008 - 8:10 AM
|- - Tigawoods   QUOTE(azian_advanced @ Feb 13, 2008 - 8...   Feb 13, 2008 - 9:04 AM
- - MaskedMan   Just to confirm the TRD strut bar part number is v...   Feb 15, 2008 - 10:24 PM
- - 99Celica   how much did you pay? I think I might go order one...   Feb 15, 2008 - 10:41 PM
- - MaskedMan   I paid $240 which is about the same from Toyo...   Feb 16, 2008 - 5:48 AM
- - Valo666   just an update regarding my parts. 2 of the 3 thin...   Feb 17, 2008 - 3:02 PM
- - MaskedMan   Care to share what parts you ordered?   Feb 17, 2008 - 3:52 PM
- - azian_advanced   the part numbers listed is all north-american. th...   Feb 19, 2008 - 7:04 AM
- - GotToyota   Anyone have any experience with that quickshift ki...   Feb 19, 2008 - 2:53 PM
- - hongkongnerdboy   gave them a part number for the celica dragon badg...   Feb 19, 2008 - 5:14 PM
|- - thespacepanda   QUOTE(hongkongnerdboy @ Feb 19, 2008 - 1...   Feb 19, 2008 - 5:37 PM
- - hongkongnerdboy   which dealership you go to? when i was in texas i ...   Feb 19, 2008 - 7:13 PM
|- - thespacepanda   QUOTE(hongkongnerdboy @ Feb 20, 2008 - 1...   Feb 20, 2008 - 4:50 PM
- - Valo666   QUOTE(MaskedMan @ Feb 17, 2008 - 3:5...   Feb 19, 2008 - 8:06 PM
- - Tigawoods   i went and they looked it up and had it there in t...   Feb 20, 2008 - 8:10 PM
- - azian_advanced   bump... added a few new items. see 2nd post.   Sep 17, 2008 - 11:09 PM
- - GotToyota   Is it possible to get that front bumper anymore? I...   Sep 18, 2008 - 12:11 AM
|- - Akirad1   QUOTE (GotToyota @ Sep 18, 2008 - 1...   Sep 18, 2008 - 12:16 AM
|- - GotToyota   QUOTE (Akirad1 @ Sep 18, 2008 - 12:1...   Sep 18, 2008 - 12:18 AM
- - azian_advanced   someone said that it was discontinued.. but if you...   Sep 18, 2008 - 9:38 AM
- - Akirad1   yeah i checked it it says 1195.10 + shipping i gue...   Sep 18, 2008 - 12:40 PM
|- - GotToyota   QUOTE (Akirad1 @ Sep 18, 2008 - 12:4...   Sep 18, 2008 - 1:30 PM
- - jmeyer   Just bought front and rear strut tower braces from...   Sep 18, 2008 - 1:19 PM
- - 97celiman   also i think the trd knob also fits the stock shif...   Sep 18, 2008 - 5:54 PM
- - azian_advanced   so the trd front strut bar is still available? i r...   Sep 18, 2008 - 9:55 PM
- - audet2604   i want trd spoiler and how much this spoiler   Sep 18, 2008 - 10:05 PM
- - azian_advanced   visit japanparts.com. last time i checked it was a...   Sep 18, 2008 - 10:36 PM
- - GotToyota   The TRD body parts are crazy expensive. Would ther...   Sep 18, 2008 - 10:44 PM
- - Akirad1   ebay for spoilers but bumpers i dunno maybe the ca...   Sep 18, 2008 - 11:03 PM
- - Rusty   QUOTE so the trd front strut bar is still availabl...   Sep 19, 2008 - 1:34 AM
- - azian_advanced   but make sure you get the right spoiler... there a...   Sep 19, 2008 - 6:38 AM
- - Akirad1   did anyone ever confirm the carina TRD 7afe wires ...   Sep 21, 2008 - 4:03 PM
- - nics   Can we STICKY this?? took me forever to find this ...   Jul 16, 2009 - 11:06 AM
- - Rusty   yeah, great list of parts (I also had the feeling ...   Jul 16, 2009 - 8:36 PM
|- - SeverX13   ^^^^^^^^^^ I WANT THAT!!!   Jul 17, 2009 - 2:24 PM
- - nics   x2!!!!!! Got P/N?   Jul 17, 2009 - 11:13 PM
- - Rusty   ummm just a second..... right the TRD Sports St...   Jul 17, 2009 - 11:53 PM
- - Keiri   I don't know if this holds true anymore but I ...   Jul 18, 2009 - 12:21 AM
- - BonzaiCelica   http://cgi.ebay.com/ebaymotors/JDM-Toyota-...sQ5fA...   Jul 18, 2009 - 12:25 AM
- - Rusty   ^ yeah forgot to add the TRD steering wheel & ...   Jul 18, 2009 - 1:51 AM
- - 2bcelica   The TRD steering wheel is really nice and sturdy. ...   Jul 18, 2009 - 7:20 AM
- - azian_advanced   i just made a couple of changes and fixed one brok...   Dec 11, 2009 - 3:37 PM
|- - nics   QUOTE (azian_advanced @ Dec 11, 2009 - 1...   Dec 11, 2009 - 7:38 PM
- - Random_Stranger   Why is this not stickied? I found this thread ver...   Dec 11, 2009 - 7:53 PM
- - nics   i asked to sticky this way back in july, nothing h...   Dec 12, 2009 - 1:29 AM
- - BonzaiCelica   hmm I need to find myself a japanese friend to tra...   Dec 23, 2009 - 1:56 PM
- - Rusty   check TRD japan, go through part section   Dec 24, 2009 - 12:24 AM
- - BonzaiCelica   I gave my toyota dealer the version 2 TRD air filt...   Nov 8, 2010 - 10:36 PM
- - azian_advanced   Version 2 is part of the newer series of TRD part ...   Nov 9, 2010 - 8:26 AM
- - presure2   if nobody lets a mod know, then we cant do anythin...   Nov 9, 2010 - 8:42 AM
- - Rusty   has been for a while in the General discussion sti...   Nov 9, 2010 - 12:21 PM
- - BonzaiCelica   QUOTE (azian_advanced @ Nov 9, 2010 - 8...   Nov 9, 2010 - 8:35 PM
- - Rusty   those websites sell Japanese specific parts. USDM...   Nov 10, 2010 - 2:35 AM
|- - BonzaiCelica   QUOTE (Rusty @ Nov 10, 2010 - 3:35 A...   Nov 10, 2010 - 3:31 AM
- - lagos   Version 2 SPRINGS LOWERING SET PTR04-20940-08 ...   Nov 10, 2010 - 11:47 AM
- - BonzaiCelica   New TRD GT-4 Coilover Kit for the Circuit at ...   Nov 10, 2010 - 9:24 PM
- - BonzaiCelica   these cartridges are so darn expensive!!...   Nov 15, 2010 - 8:30 PM
- - BonzaiCelica   how loud is the decibal rating on the ST202 TRD Ex...   May 18, 2011 - 12:56 AM
- - BonzaiCelica   anybody know???   May 20, 2011 - 4:10 AM
- - Needles   the full description is really helpfull lol, if i ...   May 23, 2011 - 1:53 PM
- - BonzaiCelica   many European and Japanese Members that buy TRD Co...   Jul 20, 2011 - 1:24 AM
- - d_boice   What is the part number for the ((21. TRD rear spo...   Feb 3, 2012 - 3:51 PM
Lo-Fi Version Time is now: August 26th, 2026 - 3:50 PM
