Jan 14, 2008 - 9:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
hey guys and girls, i've compiled a complete list of TRD parts for the 6th gen. If there are any that i've missed or any information i should add, feel free to post them or let me know and I will put them up..
..have a good read Important: All parts listed were recognized through the U.S. ToyotaWorld.com parts search engine and the following prices are in USD. So these are the North American version part numbers of TRD Parts. Japanese TRD part numbers can be found at the link I provided at the end of this post. Other genuine toyota parts sites are: Toyota Parts Cheap.com and 1st Toyota Parts.com if you want to compare prices. Note: All parts have been identified correctly but have unconfirmed availability, so I'd suggest to verify with the parts dept before placing an order online. more TRD parts can also be found from Valo666's thread (TRD Parts and #s) 1. TRD Front Strut Brace ![]() BRACE ASSY,STRUT TOW 00602-53607-006 $223.84 ![]() ^image taken from the TRD USA 2000 model catalog Note: THIS ITEM IS DISCONTINUED 2. TRD QuickShift Kit ![]() ![]() Version 1 QUICKSHIFTER 94-97 00602-30301-004 $154.89 Version 2 SHIFTER QUICK KIT PTR04-20940-04 $166.44 Note: Not sure what the difference is between the two, but one of them will shorten the throw by 40% from stock. Note: THIS ITEM IS DISCONTINUED 3. TRD Lowering Springs ![]() ![]() Version 1 SPRING SET,LOWERING, 00602-48130-008 $196.34 Version 2 SPRINGS LOWERING SET PTR04-20940-08 $201.40 Note: Not sure what the difference is between the two. 4. TRD Performance Brake Pads ![]() HP (High Performance) 1994-1997 Celica with 4 wheel disc brakes (ie. GT and GT-S) BRAKE PADS (Front) 00602-04491-015 $50.68 1994-1996 Celica with rear brake drums (ie. ST) BRAKE PAD SET,FRONT, 00602-04491-019 $51.33 HPZ (High Performance Z-Rated) (only available for ST) 1994-1996 Celica with rear brake drums (ie. ST) BRAKE PADS (Front) 00602-04491-020 $80.17 Note: I'm assuming the 'Z' in HPZ is of a higher performance model? It sucks how it's only available for ST 5. TRD High Flow Air Filter ![]() Version 1 AIR FILTER 00602-17801-001 $47.87 Version 2 FILTER AIR 3.0 V6 (don't be fooled by the '3.0 V6'. this filter is used in other models too.) PTR05-06990-01 $49.40 ![]() CLEANING KIT AIR FIL (optional) PTR05-00000-CL $16.72 6. TRD Type-N High Pressure Radiator Cap ![]() CAP RADIATOR 18.5PSI (or 127.55 kPa or 1.3 kg/cm) PTR04-00000-03 $29.30 7. TRD High Performance Oil Filter ![]() Version 1 (Red) TRD OIL FILTER 00642-90915-002 $18.48 Version 2 (White) FILTER OIL PTR14-00000-05 $11.40 Version 3 (Black) PTR43-00080 $9.95 Note: VERSIONS 1 & 2 ARE DISCONTINUED Version 3 still available. I just ordered 4 last week (May 11, 2011). 8. TRD Oil Filler Cap ![]() Version 1 CAP, OIL FILLER 00602-12108-001 $44.11 Version 2 (shown above) OIL CAP,SCREW-ON BIL 00602-12108-002 $40.28 9. TRD Gear Shift Knob ![]() A. SHIFT KNOB BLK ALUM 00602-36303-005 $33.43 B. SHIFT KNOB SILV ALUM 00602-36303-003 $33.43 C. KNOB, SHIFT, LEATHER 00602-36303-001 $22.00 ![]() D. KNOB SHIFT BALL TYPE PTR04-00000-06 $22.04 E. KNOB SHIFT LEATHER PTR04-00000-05 $58.07 F. TRD TACOMA SHIFT KNB PTR26-35060 $36.00 Note: IIRC, D is the only one that is a direct install to the stock shifter. The rest may require modifications to fit. 10. TRD Clutch Kit ![]() For AT200 Celica (ST Models) only CLUTCH SET, HI-PERF 00643-31200-006 $304.70 This post has been edited by azian_advanced: May 20, 2011 - 10:03 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
| Lo-Fi Version | Time is now: March 27th, 2026 - 6:24 PM |
