> quick question, about front strut bolts
post Jan 15, 2008 - 7:21 PM
96bluevert
Joined Mar 19, '07
From Washington
I bought a front strut bar from another member on here and recieved it today. But when I tried loosing the bolts to install it, they wouldn't budge. After some reaserching on here and other car forums I found that this is a common problem when installing front strut bars. I know most people recommend just putting a LOT of muscle into it, but I'm an average guy and don't have power tools tongue.gif So is there any easier way that you guys know of to loosen the bolts so I can install the bar..? Also I guess the stock spec is to torque to 100 lbs..again I don't have power tools, so what would be the best way to determine 100lbs using regular renches?
post Jan 15, 2008 - 9:30 PM
Hanyo
Joined Aug 16, '03
From Bay area
add a metal pipe and get a breaker bar.
those nuts should not be on there that tight, is there rust on there?
try to use wd-40 or losen the bolts?
post Jan 15, 2008 - 9:38 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
Going to need a lot of leverage. Breaker bar and a pipe works wonders. Even better than pneumatic tools some time.
FlickR
post Jan 15, 2008 - 11:49 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Dude, breaker bar FTW. I'd pick my good ol breaker bar over my impact wrench doing suspension work any day. No lie. Does it really matter if you over torque the top bolts holding the strut?
94 Celica gt white (sold)
post Jan 16, 2008 - 4:22 AM
96bluevert
Joined Mar 19, '07
From Washington
QUOTE(bccentaur3 @ Jan 16, 2008 - 4:49 AM) [snapback]631202[/snapback]
not over torqing them, but undertorquing would not be good tongue.gif. I think I'll try some WD-40 and a breaker bar. Should be enouph to get them loose, dnt you think? Hopefully will get to use my friend's torq wrench to get it tightened well enouph smile.gif
thnks for the help guys.
post Jan 21, 2008 - 8:16 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
cheater bars are the number one tool in any garage!
post Jan 21, 2008 - 10:09 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
its spelled ENOUGH not enouPH.
could be just a little frozen in. ever tried hitting it lightly to see if you can shock it loose. another way is to tighten the bolt then loosening it to get it loose.
post Jan 22, 2008 - 1:30 AM
jdg371
Joined Jun 14, '05
Cheater Pipe is your best friend. You can make a DIY version for youself. Take a hollow steel pipe, cut it to your desired length. Mine is around 2.5FT. There you go, a cheater pipe!
post Jan 22, 2008 - 7:05 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
I still say hire big mexican wrestler to do it for you but nobody listens.....
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Jan 22, 2008 - 7:08 PM
Havok1997GT
Joined Nov 23, '07
From Houston TX
QUOTE(thespacepanda @ Jan 22, 2008 - 7:05 PM) [snapback]633394[/snapback]
post Jan 22, 2008 - 7:15 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
Bright spandex + Pandas = No
"What?"
"Just do it."
"No problem."
post Jan 23, 2008 - 1:58 AM
Celicam8
Joined Nov 17, '07
I used my lugnut remover... worked perfectly
Lo-Fi Version Time is now: June 25th, 2026 - 3:06 PM
