Jan 18, 2008 - 8:57 AM
Enthusiast ![]() Joined Dec 15, '07 From Windy City Currently Offline Reputation: 0 (0%) |
how hard is it to replace your axles and rear strut mount bushings? im probably going to pick up a project celica car and that's what it needs...
Jan 18, 2008 - 3:01 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
Besides gettin the drivers side axle pulled from the tranny.. more time consuming than hard.
I would get new axle seals and replace those. Also be careful about which axles you get; many of the cheaper rebuilds will go pretty quickly. I'm sure others will tell you some good brands (I bought the cheapies.) The sway bar links can be a PITA as well if they need to come out when replacing the top mount. I replaced those at the same time so I'm not 100% positive if they need to be removed.. But get plenty of PB blaster and be prepared to replace those as well. -------------------- ![]() |
Jan 18, 2008 - 3:19 PM
any body have pictures of the strut bushings? is it the cap that holds the 3 strut mounts?
Jan 18, 2008 - 3:22 PM
clicky
hopefully that link works. KYB is OEM. Someone here on the board bought the moog mounts and had bad luck with them. -------------------- ![]() |
| Lo-Fi Version | Time is now: August 22nd, 2026 - 7:21 AM |
