Jan 21, 2008 - 9:30 PM
Enthusiast ![]() ![]() ![]() Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) |
Hey, ive never done a sound system before, but i have two 12" JL Audio 12W0 8ohm subs. What need know is what kind of amp i would need to run these. Would a JL Audio 250/1 work? Im just a little thrown off by the 8ohm aspect of the subs. And how many channels i would need on the amp if i just wanted to run the subs. If anyone could give me a little info, and help clarify some things for me thatd be great.
DSToyo Sub/Amp Q' Jan 21, 2008 - 9:30 PM
MaskedMan The JL Audio 250/1 will be a good amp to use with ... Jan 22, 2008 - 12:26 AM
DSToyo awesome, even with them being 8ohms. As you can se... Jan 22, 2008 - 11:45 AM
DSToyo bump Jan 23, 2008 - 4:14 PM
Driveby Wire the two 8ohm subs in paralell then the amp wi... Jan 23, 2008 - 6:17 PM
DSToyo alright thanks, that helps alot
my subs are 125wa... Jan 23, 2008 - 6:54 PM
DSToyo ...and what gauge wires would be needed? 8? Jan 24, 2008 - 3:14 PM
itssteve 8ga should work but i think that 4ga would be bett... Jan 24, 2008 - 10:20 PM
DSToyo aight yeah, thats what i was thinking thanks. what... Jan 25, 2008 - 2:58 AM
itssteve 4ga wire will be fine with power up to around 1200... Jan 25, 2008 - 10:37 AM
pittfirefighter use 4 gauge wire and go with the JL amp... the 250... Jan 25, 2008 - 5:20 PM
DSToyo ok thanks alot! that really helps, sounds pret... Jan 25, 2008 - 5:25 PM
pittfirefighter no stick with JL stuff... they put a lot of qualit... Jan 25, 2008 - 5:32 PM
DatDudeJoey u should get a mmats amp there really nice with a ... Jan 26, 2008 - 2:03 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 1st, 2026 - 5:06 AM |
