Jan 21, 2008 - 10:35 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
i was wondering what people on here who have the 3s swap...how much boost are you running on your set up and how much is the most you can safely run? now i understand it depends on a lot of different things..such as proper tuneing and how well the motor is built to handle more boost...but if you dont mind posting how much you are currently running and and estimate of how much you could run max. with a simple set up such as: 2nd gen 3s swap...full 3" turbo back exhaust...FMIC...CAI and water injection...i know water injection helps a lot so just give me some figures on what you think you would be able to run max. with that set up and proper tuneing..i know lagos is runnin either 15 or 16..anyone higher then that?
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
95st-celica question about boost on the 3s Jan 21, 2008 - 10:35 PM
devilsden97 15 to 17psi is the max ive seen. Simply because th... Jan 22, 2008 - 1:14 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 7:54 PM |
