> 7AFTE TURBO SETUP
post Jan 22, 2008 - 12:12 AM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
Anyone with a 7afte please ans if this setup is good or anthing needs to be changed: Can i run around 12psi with this setup?
- T3 turbo
- Custom down pipe
- Jgs tools manifold
- Turboxs manual boost control
- Short ram intake and filter
- Vortech 12:1 Fuel management unit with fuel lines
- Walbro 255lph supra fuel pump
- Lime green top Supra 315cc Fuel injectors
- Jgs tools oil feed line kit
- Custom oil return line
- Pre tapped and fitted oil pan
- Greddy universal Intercooler piping kit
- Front mounted intercooler
- Monza SSQV Blow off valve
- Air lines
- Check valves for the MAP
- SAFC2
- Triple gauge pod
- Oil Pressure Gauge
- Boost Gauge
- Voltmeter Gauge
- NGK V-Power grade 8 spark plugs
- Stage 2 clutch
thanks for any help...
This post has been edited by mikecelica: Jan 22, 2008 - 10:54 AM
- mikecelica   7AFTE TURBO SETUP   Jan 22, 2008 - 12:12 AM
- - Harold_Fastwaker   Well, that was the original 7a build from Nik. No...   Jan 22, 2008 - 2:42 AM
- - mikecelica   what if i use larger injectors but still the check...   Jan 22, 2008 - 10:57 AM
|- - Harold_Fastwaker   QUOTE(mikecelica @ Jan 22, 2008 - 12...   Jan 22, 2008 - 2:16 PM
- - mikecelica   yeah but what im confused about is why we need a 2...   Jan 22, 2008 - 3:01 PM
|- - Turbofun   QUOTE(mikecelica @ Jan 22, 2008 - 3...   Jan 22, 2008 - 3:38 PM
- - lagos   QUOTE(mikecelica @ Jan 22, 2008 - 3...   Jan 22, 2008 - 3:33 PM
- - mikecelica   okk that makes alot of sense now, but i was also w...   Jan 22, 2008 - 3:45 PM
|- - Harold_Fastwaker   QUOTE(mikecelica @ Jan 22, 2008 - 5...   Jan 23, 2008 - 12:31 AM
- - normality78   go with proper built. get a 2bar map sensor. I dun...   Jan 22, 2008 - 9:06 PM
- - mikecelica   are the 2 bar map sensors off GM direct plug in to...   Jan 23, 2008 - 11:49 PM
- - mikecelica   what are the best spark plugs to use with a turbo ...   Jan 27, 2008 - 10:09 PM
- - Turbofun   Run on stock head gasket?   Jan 31, 2008 - 8:14 AM
- - mikecelica   yes   Jan 31, 2008 - 11:31 AM
- - mikecelica   some ppl are saying to get a thicker one to lower ...   Jan 31, 2008 - 6:33 PM
- - normality78   im sure u will run into same problem like pabel89....   Jan 31, 2008 - 9:11 PM
|- - pabel89   QUOTE(normality78 @ Jan 31, 2008 - 9...   Jan 31, 2008 - 10:01 PM
- - Turbofun   I blew my headgasket on 14 psi boost, but I think ...   Feb 1, 2008 - 4:54 AM
- - CelicaST_CALI   wtf are "air lines"????   Feb 3, 2008 - 11:43 PM
Lo-Fi Version Time is now: March 21st, 2026 - 5:21 AM
