Feb 1, 2008 - 9:41 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
hey as title says im a noob to this forum (well i signed up years ago but was too lazy to post)
ive had a few celicas, and i dont reckon ill stop there. (ST185 RC, Series 6 13b turbo RA23, widebody ST185R and the 205) currently also have a TA63 GT-TR celica as a daily. since there is no members ride thread section i could see in a quick view i thought ide post up what ive done to my bus. Ive had it for about 2.5 years, done all the work myself, including all fabrications, rebuild etc) umm thats about all i can think to add atm, if you have any questions feel free to post up, im open 2 all opinions Ride: 1994 Toyota Celica GT-Four, ST205 Group A Rallye #61 Built not bought Donk: Gen 3 3sgte. 600x300 hybrid front mount with custom (2" stainless and 2.5" ally piping) Turbosmart supersonic BOV Turbosmart Ultragate external wastegate with screamer pipe 6boost exhaust manifold ceramic coated Garrett GT3082 turbo (.64 rear, .7 front) speedflow turbo fittings stainless braided turbo oil feed Custom side feed inlet manifold with velocity stack runners Modified 2zz-ge throttle body Custom Billet aluminium oversize idler pulley Custom aluminium oil catch can Custom silver steel slave cylinder pushrod Custom carbon fibre airbox Cutsom carbon fibre CAI scoop Custom Bronze impregnated teflon shifter bush Custom twin pod 4\\\" intake pipe 3" m/s and stainless mandrel bent zaust, heat wrapped dump pipe, Apexi megaphone dunk 7" cannon with 4"dump tip TRD low temp racing thermostat, TRD high preasure radiator cap TRD oil cap TRD engine mounts TRD oil filter ARP rod bolts ARP head studs ARP main bolts NPC 5 puck brass button clutch and uprated preasure plate, (good for 350kw atw) Reco'd clutch slave and master cylinders Stainless braided clutch line Redline supershock proof lightweight gear oil Stainless braided gearbox oil cooler lines relocated geatbox oil cooler C-One sports diff mount New OE idler and tentioner bearings New OE valve spring retainers New OE valve stem seals New OE head gasket (steel) New OE gaskets and belts New OE rear main seal New OE water pump New OE clutch fork New OE throwout bearing New OE oil pump New OE flywheel bolts New OE preasure plate bolts NGK Super Silicone plug leads GReddy timing belt GReddy Profec B Spec II electronic boost controller Apexi Power FC Pro Apexi Pod x2 HKS adjustable cam gears HKS 264 deg cams HKS valve springs HKS Twin Power CDI ignition Walbro 550hp fuel pump Sard DRR fuel preasure regulator and adapter Sard fpr guage Sard 800cc injectors ACL Race Series pistons ACL Race Series rings ACL Race Series engine bearings ACL Alu glide little end bearings deburred, balanced & blue printed shot peened rods and crank recut valve seats (3 angle stainless steel valves from the factory) combustion chambers cleaned up and deburred. acid dipped block heat proof painted exhaust manifold and turbine housing red rocker cover stainless cap screws Removed EGR valve Removed purge tank Davis Craig thermo fan Samco blue silicone hose. Extra engine earths Outer: JDM tinted tail lights clear side repeaters clear (and inner tinted) front indicators semi debadged lipped guards dark tinted windows Slimline and offset number plate :lolhit: Projector headlights Narva 100mm fog lights Apex cone HID\\\'s 6000k LED parkers "Mook" "GT-Four" spoiler raiser block infills Inner: Momo steerer TRD type 2 gearknob turbo timer Autometer phantom II boost guage Autometer phantom II Oil preasure guage White face dials by "mook" Leather recovered centre console and gearshift boot Stezza n other: Pioneer mp3 head unit Pioneer 4 channel amp (splits) Pioneer 2 channel amp (sub) JL Audio 6.5" front splits JL Audio 6" rear splits JL Audio 10" dvc sub Pivot voltage stabaliser Stinger ground loop isolater x2 Odyssey dry cell battery (under drivers seat) 2 way pageing alarm LED interior lights LED electric window control light LED indicators LED heater control lights LED dash lights Suspension and stoppers: Tein 1 1/2 drop 4.5kg/3.7kg spring rate spring KYB super special adjustable shocks Slotted rotors all round Project Mu B spec pads Cusco adjustable pillow ball strut tops Cusco 4 point chassis brace Whiteline adjustable rear sway bar Racing Beat adjustable end links. New fig 8 joints New leading and trailing control arms Nolethane front sway bar bushes Stainless braided brake lines Motul DOT 5.1 fluid Rice red and clear coated brake calipers :lolhit: [/size] Wheels: Momo m1 18x8.5\\\" stock ST205 16" 3 spokers (for racing) Future Plans: replace all bushes TRD corners TRD side skirts Custom or aftermarket front strut brace ally radiator and aftermarket oil cooler and more: thanks to: Don (aka dons bodyworks) for the continuous use of the hoist/pit, and painting. Tangcla for the continuing seach for parts ART in melbourne for the tune At the time of writing its making 265 kw atw on 22psi, with the radiator sturggling with engine temps. Best from the stock turbowas 204 kw atw. best 1/4 mile was 12.8 @ 108 mph (stock turbo, 200kw atw) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Hot Rod :lolhit: ![]() Good head. ![]() If you squint you can read HKS 3SG ![]() ![]() ![]()
This post has been edited by Cuts_the_Pilot: Aug 13, 2009 - 2:09 AM -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
Feb 1, 2008 - 9:43 PM
![]() Enthusiast ![]() ![]() Joined Jan 4, '08 From Clearwater, Fl Currently Offline Reputation: 5 (100%) |
That is a sick car.
Feb 1, 2008 - 9:46 PM
Enthusiast ![]() Joined Dec 23, '07 From Calgary, AB Currently Offline Reputation: 0 (0%) |
x2 I love those rims they look awesome |
Feb 1, 2008 - 9:52 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) |
my expression ----> o.O
This post has been edited by hongkongnerdboy: Feb 1, 2008 - 9:52 PM -------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
Feb 2, 2008 - 1:09 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
beautiful!!
i would add a new strut bar to that bay. TRD perhaps? :drooling: This post has been edited by goferris: Feb 2, 2008 - 1:10 AM -------------------- |
Feb 2, 2008 - 1:19 PM
Enthusiast ![]() ![]() Joined Jun 26, '07 From Greece Currently Offline Reputation: 2 (100%) |
This is a sick,sick car! Man i love it!
-------------------- Face your fears, Live your dreams!!!
Feb 3, 2008 - 4:59 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
Simply amazing!
Feb 3, 2008 - 11:08 AM
beautiful car
impresssive. -------------------- |
Feb 3, 2008 - 11:28 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
wow. those rims go perfectly with your car. what size tires are you using?
And a very clean engine bay. Thanks for sharing. |
Feb 3, 2008 - 12:11 PM
Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
Nice car mate...bet that kicks some serious arse.
Feb 3, 2008 - 12:32 PM
you had me at :
Ride: 1994 Toyota Celica GT-Four, ST205 Group A Rallye #61 all the rest is just yummy goodness. one hell of a ride. -------------------- Former Team 5SFTE pro member ;)
Feb 3, 2008 - 1:19 PM
![]() Enthusiast ![]() ![]() ![]() Joined Oct 31, '02 From Boise, ID Currently Offline Reputation: 2 (100%) |
I want your car!
Looks aweome. I bet thats totally a kick to drive. Awesome Work. You got any highres photos I could use for desktop? -------------------- ![]() psalm 69 |
Feb 3, 2008 - 8:42 PM
thats for all of your replies and comments folks.
the wheels and tyres are: Momo m1, 18x8.5", tyres are maxis 225x40, im seriously considering selling these for some works, or volks etc. should be some high res pics in my profile thingo, feel free to leach all my pics Yep its pretty good to drive, its very smooth and linnear in the power delivery. Will be better when i finish the turbo upgrade and get the snap into boost that we all love:D im let to loose a race in it, street or strip. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Feb 4, 2008 - 1:45 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Clean and beautiful. I so love seeing a clean stock [or OEM only] exterior with muscle under the hood. The Group A Rallye - IDK speechless. Well thought out mods too.
cough* Featured Ride *cough -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Sep 24, 2008 - 6:12 AM
hey guys. Just thought ide give a little update.
![]() ![]() This is my new suspension as of a couple of months ago. KYB Super Special for Street adjustable shocks, with my ultra low kings streched 12mm, new bump stops, Cuscp pillow ball adjustable strut tops, Cusco 4 point underbody brace. The reason i didnt get coil overs are unless your driving a pure track car they arnt worth it, your on road driveablility goes to sh!t with springs that are way to stiff and stuff all suspension travel, especially if your buying the el cheapo d2/g4 coil overs. Tiens are worth 3k + for a 205, and im of the opinion its not worth it, coilovers are just a matched spring and shock combination with height and dampening adjustment. I dont want to change my height, and its your shock adjustment is what changes handling. Thats just my opinion and some people no doubt dont agree. The ride now, fncken awsome, its so much better now, i didnt think it could improve much, but man its sick. ![]() ![]() Ok this is the new project while im saving for a turbo/manifold/external gate upgrade. this is the start of a new pleum, velocity stack runners (for better off boost performance and driveablility) 2zz throttle body (8mm bigger then the 205 unit). Its going to be side feed and around 2.5 litres capacity....should be the balls.
This post has been edited by Cuts_the_Pilot: Sep 24, 2008 - 6:14 AM -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Sep 24, 2008 - 8:14 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From san antonio tx. Currently Offline Reputation: 12 (100%) |
Your cars just sick! Thanks for the update, the super specials, were they expensive and is the last pic of your car with your new suspension installed?
-------------------- Sorry, no animated sigs allowed.
Sep 24, 2008 - 7:06 PM
if your talking about the last pic with the brake rotor in it then yep thats as i was installing the rears.
if your talking about the pic with the white group A 185 and my 205 Group A then also yes this is post suspension upgrade pic. and were they expensive???.....ohh yes, to my door in usd they were around $1700 for all 4 shocks, no springs, no bump stops just the struts. i could have bought inserts for the stock struts but im not into that, in my opinion your better off gettin all new units with warrenty etc insted of getting your old ones out and having to machine the crimped bit out etc. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Sep 25, 2008 - 1:48 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
wow ITB on a turbo car, a bit different, but can I ask why a 2ZZ TB and not a red/black BEAMS TB?
Sep 25, 2008 - 2:13 AM
its not going to be itb but it shall have the velocity stacks in pic.
2zz because its bigger. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Sep 25, 2008 - 5:07 PM
ok
wow I didn't know that -------------------- |
| Lo-Fi Version | Time is now: July 8th, 2026 - 6:18 AM |
