Feb 2, 2008 - 4:53 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
pretty much as the topic and description state...
i know the 3sgte is a 2.0l 16v dohc turbo'd engine and i know most the specs.. is there a chance u could swap in a 4age 20v head? maybe bore out the head a bit? so it'd be a 3sgte 2.l 20v dohc turbo w/just the single throttle body? not the itb's used in the 20v.. too much work for those although w/great benefit... thanks everyone just curious.. -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Feb 2, 2008 - 5:03 PM
Enthusiast ![]() ![]() ![]() Joined Apr 12, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
I can't seem to look puzzled enough to express my emotion.
Anyway it may be possible if you have a machine shop in your backyard but putting the head for a 20V on the 3S really just won't work without massive fabrication. You'd bend valves faster than a stock minivan with a 150 shot of nos. (it happened) -------------------- "He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn." "What?" "Just do it." ".......He said yes." "Tell him you are not darklings. He should open up." ".......Sweet. Thanks." "No problem." |
Feb 2, 2008 - 5:28 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
QUOTE(cjh4l22 @ Feb 2, 2008 - 1:53 PM) [snapback]637272[/snapback] pretty much as the topic and description state... i know the 3sgte is a 2.0l 16v dohc turbo'd engine and i know most the specs.. is there a chance u could swap in a 4age 20v head? maybe bore out the head a bit? so it'd be a 3sgte 2.l 20v dohc turbo w/just the single throttle body? not the itb's used in the 20v.. too much work for those although w/great benefit... thanks everyone just curious.. why? |
Feb 2, 2008 - 5:30 PM
no, just no.
dont ask why. -------------------- Former Team 5SFTE pro member ;)
Feb 2, 2008 - 6:27 PM
DO IT!
Feb 2, 2008 - 6:33 PM
Enthusiast ![]() Joined Nov 19, '07 From Easton, Maryland Currently Offline Reputation: 0 (0%) |
btw: if your worried about the ITB's being to much work...
This post has been edited by Zelstin: Feb 2, 2008 - 6:37 PM |
Feb 2, 2008 - 7:02 PM
Enthusiast ![]() ![]() ![]() Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
Why can't it be done?
Feb 2, 2008 - 7:28 PM
QUOTE(laff09 @ Feb 2, 2008 - 7:02 PM) [snapback]637305[/snapback] Why can't it be done? same reason why you cant bolt a 7a trans to a 3sgte. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 2, 2008 - 8:15 PM
Enthusiast ![]() ![]() Joined Apr 11, '06 From Tasmania Currently Offline Reputation: 0 (0%) |
Spot the difference.
3S Head ![]() 4age and 4age 20v ![]() This post has been edited by GreenyST204: Feb 2, 2008 - 8:17 PM -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Feb 2, 2008 - 8:35 PM
Enthusiast ![]() ![]() Joined Oct 10, '07 From Sunrise Florida Currently Offline Reputation: 0 (0%) |
correct me if im wrong (im just a dumb kid) but its made to fit a whole different block family, its a little more understandable to fit a S-block head to a different S-block, but still not easy at all. it would be nice to do though...
Feb 2, 2008 - 9:13 PM
ok sorry for insulting anyone in that. didn't mean to ask a 'stupid' question.. i was just curious.. i came up w/it today while i was driving. i just know that some ppl get better head flow w/20valves.. thats all. anywho, yea i didn't realize none of the coolant lines matched and it would require that much machining. well thanks for answering my question.
Feb 3, 2008 - 12:13 AM
Good Idea but wrong way to go about it,
should look at getting a 4agze then putting the 20v head on it and turboing it. -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Feb 3, 2008 - 12:18 AM
QUOTE(GreenyST204 @ Feb 3, 2008 - 5:13 AM) [snapback]637373[/snapback] Good Idea but wrong way to go about it, should look at getting a 4agze then putting the 20v head on it and turboing it. Won't it be kinda tricky turboing an engine with vvt? -------------------- "He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
QUOTE(cjh4l22 @ Feb 2, 2008 - 9:13 PM) [snapback]637335[/snapback] ok sorry for insulting anyone in that. didn't mean to ask a 'stupid' question.. i was just curious.. i came up w/it today while i was driving. i just know that some ppl get better head flow w/20valves.. thats all. anywho, yea i didn't realize none of the coolant lines matched and it would require that much machining. well thanks for answering my question. its cool man. you didnt insult anyone. the 3s head probably outflows the 20v head by a long shot (im sure people will debate that).. but there is really no reason for a head swap on the 3s. you just upgrade the cams, intake manifold, and gears and you can flow as much power as you will ever need. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 3, 2008 - 1:33 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
QUOTE(thespacepanda @ Feb 2, 2008 - 10:18 PM) [snapback]637374[/snapback] QUOTE(GreenyST204 @ Feb 3, 2008 - 5:13 AM) [snapback]637373[/snapback] Good Idea but wrong way to go about it, should look at getting a 4agze then putting the 20v head on it and turboing it. Won't it be kinda tricky turboing an engine with vvt? 4agze isnt vvt -------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Feb 3, 2008 - 1:22 PM
QUOTE(celicaST @ Feb 3, 2008 - 1:33 AM) [snapback]637397[/snapback] QUOTE(thespacepanda @ Feb 2, 2008 - 10:18 PM) [snapback]637374[/snapback] QUOTE(GreenyST204 @ Feb 3, 2008 - 5:13 AM) [snapback]637373[/snapback] Good Idea but wrong way to go about it, should look at getting a 4agze then putting the 20v head on it and turboing it. Won't it be kinda tricky turboing an engine with vvt? 4agze isnt vvt But when you put a vvt head on it... |
Feb 3, 2008 - 1:56 PM
Heheheheheheh....
QUOTE(GreenyST204 @ Feb 3, 2008 - 5:13 AM) [snapback]637373[/snapback] Good Idea but wrong way to go about it, should look at getting a 4agze then putting the 20v head on it and turboing it. BUT... the 4AGZE has basically the same rods/internals as a silvertop 20V... minus the pistons. Only a blacktop has different rods, but those rods are still plenty strong. This post has been edited by Kwanza26: Feb 3, 2008 - 1:56 PM -------------------- "It's ok to be naked girl... I'm an artist!"
Feb 3, 2008 - 3:45 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
I bet the bore centers are different between the s-series and a-series blocks. That alone kills the idea.
-Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Feb 19, 2008 - 2:23 PM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '04 Currently Offline Reputation: 0 (0%) |
Put a 20v head on a 7a block with a 1zz crank and 2zz rods, then put on some 4a pistons. It would take some machine work but you would get just shy of 2L.
Feb 19, 2008 - 2:52 PM
QUOTE(lagos @ Feb 2, 2008 - 8:27 PM) [snapback]637300[/snapback] DO IT! YES! -------------------- |
| Lo-Fi Version | Time is now: July 11th, 2026 - 11:22 AM |
