Feb 4, 2008 - 7:04 PM
I had to replace the wheel bearing on sarah's coupe today and when i pulled it apart i found out that the hub was worn down alot due to the absolutly terrible bearing.
Any ways, i just need the hub/spindel. Pretty much the peice where the rotor mounts to with the studs where it connects into the actuall spindel its self. |
Feb 5, 2008 - 7:44 PM
Enthusiast Joined Feb 5, '08 From Pittsburgh,PA( New Kensington) Currently Offline Reputation: 0 (0%) |
QUOTE(Valo666 @ Feb 4, 2008 - 7:04 PM) [snapback]637997[/snapback] I had to replace the wheel bearing on sarah's coupe today and when i pulled it apart i found out that the hub was worn down alot due to the absolutly terrible bearing. Any ways, i just need the hub/spindel. Pretty much the peice where the rotor mounts to with the studs where it connects into the actuall spindel its self. is it an ST or GT? I have both front assembly's still together with calipers and good rotors for the ST. -------------------- I Drive One of a Kind's
Feb 5, 2008 - 8:46 PM
st and all i need is just the hub where it presses into the bearing on the spindel.
Feb 14, 2008 - 8:59 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
mind me mooching off this thread and saying i need a rear ds hub for an st?
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
| Lo-Fi Version | Time is now: August 26th, 2026 - 1:06 AM |
