3 Pages V  < 1 2 3
> engine rebuild project, PIX ADDED, more to come...
post Apr 6, 2008 - 4:54 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
ok guys sorry for the wait!
ok so i finished her up and she actually started up first try. i was very surprised.
anyway, engine sounds great but I'm still having a couple issues, I have a speed sensor thats not working, I need to swap a motor mount (anyone got a spare front mount?) and an exaust leak.
The exaust leak will be fixed very soon but other than that shes ok. I'll put some pics up in a bit. she making me angry right now cuz she died in the rain and there is no power getting to anything now... Figure its a fuse, maybe you guys can help me out...
http://www.6gc.net/forums/index.php?showto...mp;#entry661935
This post has been edited by nightryder: Apr 6, 2008 - 4:58 PM
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Apr 6, 2008 - 5:04 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
i have a spare front mount
Driving a 5SFTE and LOVIN IT!!!!!!
http://www.myspace.com/17psicelica <-- celica engine build pics
post Apr 6, 2008 - 8:18 PM
QUOTE(nightryder @ Apr 6, 2008 - 5:54 PM) [snapback]661939[/snapback]
I told you to plug in the speed sensor, it's just not plugged into the top of the tranny.
The front mount is about $40 IIRC from toyota
check the fuses and also check the battery cables and alternator wires.
All the grounds too.
post Apr 7, 2008 - 12:57 AM
nightryder
Joined Sep 29, '05
QUOTE(Batman722 @ Apr 6, 2008 - 8:18 PM) [snapback]662015[/snapback]
i did plug in the speed sensor, its still not working. did check battery cables and alt wires (especially my "trouble" wire/plug.
post Apr 15, 2008 - 5:11 PM
nightryder
Joined Sep 29, '05
ok soo I went back into the wiring and went through everything.
every ground, ecu, fuses, relays...
I pulled out the good ol' multimeter and found a drop in voltage at the ground on the tranny. So when I went to unbolt it I noticed that it was pretty tough to move. Turns out it was all corroded from a certain amount of clutch fluid being spilt on it or something. So i cleaned it up, put on some corrosion protection and she started up...
weird thing is...
now my speedo works again(?)
i wont argue though, now all i got is that exhaust leak and the motor mount.
ill be posting some pics and some some sound clips once the exhaust is all set.
post Apr 15, 2008 - 9:33 PM
RichieRichJP
Joined Feb 7, '08
From Colorado Springs, CO
How much did it cost to get the crankshaft lightened and balanced? I heard that it usually costs about $1500
post Apr 17, 2008 - 9:22 AM
nightryder
Joined Sep 29, '05
QUOTE(RichieRichJP @ Apr 15, 2008 - 9:33 PM) [snapback]665001[/snapback]
ooooo, I dunno man. I guess it would depend on the machinist and whether or not you pulled it out the the block for him.
-new pistons, rods, rings and bearings (oversized)
-Cylinder bore
-Deck cut
-honed
-crank; ground and balanced
-repainted block and valve cover and other various parts
-reassemble block
he did all this for $796.... I guess it just depends where you go
This post has been edited by nightryder: Apr 17, 2008 - 9:23 AM
post Apr 18, 2008 - 11:30 AM
RichieRichJP
Joined Feb 7, '08
Thanks!
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: September 15th, 2026 - 1:08 PM
