> failed emmision test PLEASE HELP
post Feb 8, 2008 - 11:37 AM
dolfingolf
Joined Feb 5, '08
From cheshire
mad.gif mad.gif mad.gif MY 1993 2.0Ltr ST202 FAILED THE EMMISION TEST BADLY WITH A READING OF 8.093 ON Co , AND THE LAMBDA READIND WAS UP,THE MOT STATION SAID THAT WAS NOT CAT OR LAMBDA SENSOR RELATED AS THE READINGS WERE TO HIGH FOR THESE TO BE AT FAULTAND SUGGESTED IT WAS MORE LIKELY TO BE THE ENGINE TEMPERATURE SENSOR,
CAN ANYONE TELL ME IF THIS IS THE CASE AND IF SO WHERE IS THIS LOCATED AS I AM AWARE THERE ARE TWO OF THEM ,THANKS TO ANONE WHO CAN HELP .MY CONTACT NUMBER IS 01606 552475
This post has been edited by dolfingolf: Feb 8, 2008 - 11:39 AM
post Feb 8, 2008 - 12:21 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
IN ORDER TO HELP YOU IT WOULD HELP IF YOU PLEASE STOP YELLING wink.gif and also for us to know exactly what, if any other symptoms your car has. Is your check engine light on? Are you getting really poor gas mileage? I believe if your engine temp sensor were failing, your CEL light would be on. I don't know where the engine temp sensor is located on your particular engine, but I can show you where on mine it is... also, I believe if you go to any auto parts store, they can help you too. It is a readily available part, VERY easy to replace, and not even expensive! (mine was $20 USD). I also believe there's only one on your engine (but don't take my word for that, I don't know your engine at all, I just know the other engines have only one)
Edit: see pic below for location. Gray part is electrical connector, brass part is the sensor itself. Just unscrews from the block.
This post has been edited by GriffGirl: Feb 8, 2008 - 12:34 PM
post Feb 14, 2008 - 1:02 AM
6strngs
Joined May 12, '06
From Wilmington, NC
it helps to know what all your gasses were. at least the 4 main ones: HC, CO, CO2, and O2. if you can provide that info, I can better help you.
post Feb 14, 2008 - 1:11 AM
thespacepanda
Joined Apr 12, '07
From Houston, TX
It might also help if we lived somewhere that actually sold st202's. Cuuuuuz I don't know about you guys, but I don't know euro spec emissions that well.
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Feb 14, 2008 - 2:38 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
did you let your car run as you waited in line? or was it stopped. let the cat get hot so it can work.
Lo-Fi Version Time is now: September 15th, 2026 - 1:09 PM
