Feb 8, 2008 - 1:22 PM
Enthusiast ![]() ![]() Joined Apr 22, '07 From Buckinghamshire, UK Currently Offline Reputation: 2 (100%) |
hey all.
I am just about to boost my 7a, as many of you know. Anyway, I have managed to source sensors from the 3S, but what would work or does it not matter. He has both rev 2 and rev 3. Only posting here because i need to make a quick decision. Cheers Jason. |
FunkySR which 3S MAP Sensor Feb 8, 2008 - 1:22 PM
pabel89 idk but ppl say we need a 3sgte map sensor on are ... Feb 8, 2008 - 2:39 PM
rjbibeau different signals you have to retune to use the 3s... Feb 8, 2008 - 3:08 PM
FunkySR ah ok thanks. I am running a SAFC2, but will use e... Feb 8, 2008 - 3:28 PM
mikecelica jus use check valves for the map Feb 8, 2008 - 5:20 PM
presure2 QUOTE(mikecelica @ Feb 8, 2008 - 5:2... Feb 9, 2008 - 6:42 AM
laff09 This isnt 1991. Check valves should not be on your... Feb 8, 2008 - 6:42 PM
FunkySR lol. true that LAFF. I decided to go for the rev 2... Feb 8, 2008 - 6:46 PM
mikecelica ohh i see, then i guess i gota go pick one up too.... Feb 9, 2008 - 8:22 AM
presure2 QUOTE(mikecelica @ Feb 9, 2008 - 8:2... Feb 9, 2008 - 10:43 AM
FunkySR thanks guys. I will keep yo updated. I'm using... Feb 9, 2008 - 11:46 AM
pabel89 im running 8psi on my stock map sensor, i tune my ... Feb 9, 2008 - 3:21 PM
mikecelica i thoguht stock couldnt read boost? it reads -15 t... Feb 9, 2008 - 5:28 PM
FunkySR correct Mike. It reads vacuum. I think the emanage... Feb 9, 2008 - 7:10 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 10th, 2026 - 8:56 AM |
