Feb 11, 2008 - 2:34 PM
Enthusiast ![]() Joined Oct 28, '07 From UK Currently Offline Reputation: 0 (0%) |
SW Intake 1990-99 Toyota Celica
Hi, Just wondering if anyone has fitted this to a 3S-GE? If so, how'd it go? Do you like it? I especially want to know if the pipe is adapted to fit. For the 3S-GE did you use a narrowing adapter or a widening one? This all comes about because the 7A-FE has a 2.5" intake pipe, and the 3S-GE has a 2.75" pipe. I've also got it on good authority that going from 3" to 2.75" gives some performance enhancements due to positive pressure in the intake manifold. Thanks guys. |
Feb 11, 2008 - 3:13 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
man.. seems a little expensive for an intake.. seems like the $30 ebay ones would do about the same thing...
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Feb 11, 2008 - 3:17 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
Go for the K&N pal
Made for the job and comes with cold air feed pipe. For what they do i wouldn't pay more than the £80 you can get the K&N for (p.s. where's celica-club gone This post has been edited by manphibian: Feb 11, 2008 - 3:18 PM -------------------- |
Feb 11, 2008 - 3:25 PM
QUOTE(jaws4god) [snapback]640394[/snapback] seems a little expensive for an intake Expensive, yes, but the sound. OMG the sound. And it's pretty. So pretty. QUOTE(manphibian @ Feb 11, 2008 - 3:17 PM) [snapback]640394[/snapback] Go for the K&N pal As above, I guess I know the 57i works...but it's...not boring...but everyone has one! And as for celica-club...still there last time I checked. Right? I think... OK, let me check... |
Feb 11, 2008 - 3:39 PM
not worked for me all day.
Feb 11, 2008 - 3:54 PM
QUOTE(manphibian @ Feb 11, 2008 - 3:39 PM) [snapback]640406[/snapback] not worked for me all day. Really? That's odd. I'm on there right now. As per usual |
Feb 11, 2008 - 4:07 PM
QUOTE(Shink @ Feb 11, 2008 - 8:54 PM) [snapback]640415[/snapback] QUOTE(manphibian @ Feb 11, 2008 - 3:39 PM) [snapback]640406[/snapback] not worked for me all day. Really? That's odd. I'm on there right now. As per usual ??? Nothing. When i click it just tries to load for a while, then times out Absolutely EVERYTHING else works -------------------- |
Feb 11, 2008 - 4:27 PM
QUOTE(manphibian @ Feb 11, 2008 - 4:07 PM) [snapback]640421[/snapback] Nothing. When i click it just tries to load for a while, then times out Absolutely EVERYTHING else works How are the withdrawal symptoms going? That is weird. Try a restart? Different browser? |
Feb 11, 2008 - 5:00 PM
QUOTE(Shink @ Feb 11, 2008 - 9:27 PM) [snapback]640428[/snapback] QUOTE(manphibian @ Feb 11, 2008 - 4:07 PM) [snapback]640421[/snapback] Nothing. When i click it just tries to load for a while, then times out Absolutely EVERYTHING else works How are the withdrawal symptoms going? That is weird. Try a restart? Different browser? tried IE, firefox, reset, unplugged modem, not playing. rubbish. -------------------- |
Feb 14, 2008 - 3:01 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
buying expensive pod filters is like buying expensive toothpicks
-------------------- Mike W
Feb 14, 2008 - 3:27 PM
Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
QUOTE(delusionz @ Feb 14, 2008 - 3:01 PM) [snapback]641540[/snapback] buying expensive pod filters is like buying expensive toothpicks x2 ebay FTW! -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
Feb 14, 2008 - 4:55 PM
QUOTE(Shink @ Feb 11, 2008 - 1:27 PM) [snapback]640428[/snapback] QUOTE(manphibian @ Feb 11, 2008 - 4:07 PM) [snapback]640421[/snapback] Nothing. When i click it just tries to load for a while, then times out Absolutely EVERYTHING else works How are the withdrawal symptoms going? That is weird. Try a restart? Different browser? I get a Server Not Found error too. Are you sure you're not seeing the home page from your cache? Can you actually navigate the site? -------------------- ![]() |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 10:58 AM |
