Feb 12, 2008 - 5:01 PM
Enthusiast ![]() Joined Sep 26, '07 From iowa Currently Offline Reputation: 1 (100%) |
my clutch is about done for and i need my car for college/work so any heads up on problems ill run into or any advice would be great! thanks
is their a way with out removing the tranny? This post has been edited by addictions: Feb 19, 2008 - 7:51 PM -------------------- -Boss III
Feb 12, 2008 - 5:09 PM
Enthusiast ![]() ![]() ![]() Joined Apr 12, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
-------------------- "He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn." "What?" "Just do it." ".......He said yes." "Tell him you are not darklings. He should open up." ".......Sweet. Thanks." "No problem." |
Feb 12, 2008 - 5:19 PM
get yourself a good manual.
first remove all the bulk on top of transmission (battery, cables, filter etc) remove the fron tires, remove the left spindle out of way. remove the axles. (this is tricky) unbolt the tranny. drop it, then remove the pressure plate, remove the clutch. and viceversa. one day i think i will write it up, when im done with a test am preparing for. edit (added pics) this was done on a 2.2 but pretty much the same. the tranny must go down ![]() clutch already in, the flywheel was resurfaced.
This post has been edited by njccmd2002: Feb 12, 2008 - 5:57 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Feb 12, 2008 - 10:31 PM
Enthusiast ![]() ![]() ![]() Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
Actually you can do this without dropping the tranny, but you still will need to unbolt it and support it in place..... Bad part is you'll have to pull the engine. I just did mine recently, shoulda taken pics and done a mini write up. It's easy, just make sure you have everything you need(all tools, parts, fluids) before attempting this. The worst part for mine were the bolts on the control arm( have liquid wrench ready) and getting off my front rotors( RUSTED on, yes all caps for emphasis lol). Other than that it's all straight forward and pretty easy. Buy a book or find a friend that knows what they are doing around cars and you'll be fine. This wasn't my first time around an engine, but was my first time doing a clutch job by myself and at an at home setting.
This post has been edited by dabazied: Feb 12, 2008 - 10:31 PM -------------------- |
Feb 12, 2008 - 10:34 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
might wanna replace the output shaft seals while your there. also check your CV boots. but yeah check the output shaft seals before your tranny leaks.
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Feb 13, 2008 - 6:59 AM
wouldnt it be easier to pull the tranny out than the engine?
i never done it, so im curious.. I know you can pull the whole thing out with tranny and do it like that. well everybody has their style. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Feb 13, 2008 - 11:12 PM
Yeah I'm with you, how exactly is pulling the entire engine out easier than just dropping the tranny?
Feb 15, 2008 - 2:26 PM
QUOTE(addictions @ Feb 12, 2008 - 5:01 PM) [snapback]640812[/snapback] my clutch is about done for and i need my car for college/work so any heads up on problems ill run into or any advice would be great! thanks is their a way with out removing the tranny? ok so my girlfriend is making me take it to a shop now.... iam pissed! thanks for all the tips guys even tho i dont get to use them lol thanks again This post has been edited by addictions: Feb 15, 2008 - 2:26 PM -------------------- -Boss III
Feb 15, 2008 - 3:26 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
QUOTE(addictions @ Feb 15, 2008 - 7:26 PM) [snapback]641826[/snapback] QUOTE(addictions @ Feb 12, 2008 - 5:01 PM) [snapback]640812[/snapback] my clutch is about done for and i need my car for college/work so any heads up on problems ill run into or any advice would be great! thanks is their a way with out removing the tranny? ok so my girlfriend is making me take it to a shop now.... iam pissed! thanks for all the tips guys even tho i dont get to use them lol thanks again You must be cold not wearing the pants. LOL Just kidding with you. Yeah, after reading this, I would be a little nervous attempting this myself without someone there to help or guide me. I just paid $750 to have mine done. Though I would like to try it myself sometime when I buy a better clutch. And by the way, that sounds like a good woman there. Looking out for your best interests. This post has been edited by Random_Stranger: Feb 15, 2008 - 3:27 PM -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Feb 15, 2008 - 7:10 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
make sure they replace your axle seals and rear main seal at the same time
Feb 15, 2008 - 8:19 PM
Definitely a good woman lookin out for best interests there..... I wasn't saying pulling the motor out was easier, the question was is there another way to change it without takin out the tranny..... I thought everyone would get that the 2nd option was worse since i said "bad part is..." lol...... but yeah, good luck with the shop, make sure they use quality parts and get the other stuff replaced as well as mentioned above
Feb 16, 2008 - 8:10 PM
QUOTE(dabazied @ Feb 15, 2008 - 8:19 PM) [snapback]641954[/snapback] Definitely a good woman lookin out for best interests there..... I wasn't saying pulling the motor out was easier, the question was is there another way to change it without takin out the tranny..... I thought everyone would get that the 2nd option was worse since i said "bad part is..." lol...... but yeah, good luck with the shop, make sure they use quality parts and get the other stuff replaced as well as mentioned above ya i bought the parts from a list given to me by u guys and only spent around 300 and the shop will run me 500 so not to bad as long as it is done rite -------------------- -Boss III
Feb 16, 2008 - 9:39 PM
QUOTE(hurley97 @ Feb 15, 2008 - 2:10 PM) [snapback]641933[/snapback] make sure they replace your axle seals and rear main seal at the same time lolz i beat you in telling him -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Feb 17, 2008 - 7:14 PM
QUOTE(808celica @ Feb 16, 2008 - 9:39 PM) [snapback]642300[/snapback] QUOTE(hurley97 @ Feb 15, 2008 - 2:10 PM) [snapback]641933[/snapback] make sure they replace your axle seals and rear main seal at the same time lolz i beat you in telling him beat who to tell who what? i am so confused... lol? -------------------- -Boss III
Feb 17, 2008 - 8:34 PM
QUOTE(addictions @ Feb 17, 2008 - 2:14 PM) [snapback]642563[/snapback] QUOTE(808celica @ Feb 16, 2008 - 9:39 PM) [snapback]642300[/snapback] QUOTE(hurley97 @ Feb 15, 2008 - 2:10 PM) [snapback]641933[/snapback] make sure they replace your axle seals and rear main seal at the same time lolz i beat you in telling him beat who to tell who what? i am so confused... lol? the seals, the pics you asked for. -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
o lol ic ic. ya well thanks for all the help guys i am going to deleted this thread now
| Lo-Fi Version | Time is now: August 1st, 2026 - 9:29 AM |
