> 7AFTE, Check out page 3, one last question before the car goes to the shop
post Feb 12, 2008 - 11:20 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
Few questions i had about the 7AFTE setup:
1. Is a .45 trim t3 turbo ok size or too small? Lookng to make about 180hp or so
2. Is 3" exhaust too big, shud I go with 2 1/2?
3. Do i need an fmu if im gona use bigger injectors?
thanks for any help
This post has been edited by mikecelica: Feb 24, 2008 - 2:35 PM
- mikecelica   7AFTE   Feb 12, 2008 - 11:20 PM
- - bccentaur3   That turbo size would be good for 180. I know its ...   Feb 12, 2008 - 11:30 PM
- - mikecelica   i got an safc2, so i shud go with 2.5" exhaus...   Feb 13, 2008 - 12:06 AM
- - Celiracer18   go with 2.5" its best for a 7afte plugs i th...   Feb 13, 2008 - 1:01 PM
- - pabel89   you dont need an fmu if using bigger injectors i t...   Feb 13, 2008 - 2:47 PM
- - mikecelica   i do hav bigger injectors, i just got all my parts...   Feb 13, 2008 - 4:01 PM
|- - pabel89   no my car was choking because i didnt have it prop...   Feb 13, 2008 - 4:14 PM
- - mikecelica   ohh the injectors are off another 7afte so it shud...   Feb 13, 2008 - 5:17 PM
- - pabel89   i have a .50 A/R compressor .63 A/R turbine. prett...   Feb 13, 2008 - 5:54 PM
- - trd94   ok the probe injectors well work,but you well need...   Feb 13, 2008 - 5:58 PM
- - pabel89   listen to trd94 he helped me alot when i was build...   Feb 13, 2008 - 9:50 PM
- - mikecelica   QUOTE(trd94 @ Feb 13, 2008 - 10:58 P...   Feb 13, 2008 - 11:58 PM
- - mikecelica   i dont realy understand this graph... What does it...   Feb 14, 2008 - 12:22 AM
- - mikecelica   bump   Feb 14, 2008 - 4:46 PM
- - trd94   that is a small turbo. i have one that i used on m...   Feb 14, 2008 - 6:16 PM
- - mikecelica   i see... i still have some time now since my mecha...   Feb 14, 2008 - 9:00 PM
- - trd94   it depends on when you want the power , at what rp...   Feb 14, 2008 - 10:07 PM
- - normality78   hi trd94, perhaps u may wanna let him know the hp ...   Feb 14, 2008 - 11:08 PM
- - mikecelica   i guess i'd be happy with 180hp... plus torque...   Feb 14, 2008 - 11:20 PM
- - normality78   Actually this is what im facing now. Im still find...   Feb 15, 2008 - 7:57 AM
- - pabel89   quick question about the 7afte, oil all around you...   Feb 15, 2008 - 3:30 PM
|- - trd94   QUOTE(pabel89 @ Feb 15, 2008 - 3:30 ...   Feb 15, 2008 - 4:30 PM
- - trd94   most of my hp figures are on motor, and DD is Dail...   Feb 15, 2008 - 4:25 PM
- - pabel89   idk why all that oil was in the turbo, i clean it ...   Feb 15, 2008 - 4:42 PM
- - mikecelica   got your car back from the mechanic? as in already...   Feb 15, 2008 - 8:53 PM
- - mikecelica   Plus i was wondering can i use the stock oil pan f...   Feb 15, 2008 - 8:57 PM
|- - trd94   QUOTE(mikecelica @ Feb 15, 2008 - 8...   Feb 15, 2008 - 9:07 PM
- - trd94   the only reason i am did the rings and bearings is...   Feb 15, 2008 - 9:12 PM
- - mikecelica   I got about 105 miles on mine.. thing is i work at...   Feb 15, 2008 - 9:14 PM
|- - trd94   QUOTE(mikecelica @ Feb 15, 2008 - 9...   Feb 15, 2008 - 9:27 PM
- - pabel89   no i been driving my 7afte for a month or so, no p...   Feb 15, 2008 - 10:23 PM
|- - trd94   QUOTE(pabel89 @ Feb 15, 2008 - 10:23...   Feb 16, 2008 - 7:29 AM
- - mikecelica   yeah i thought so too... alot of ppl i know said t...   Feb 15, 2008 - 11:25 PM
|- - trd94   QUOTE(mikecelica @ Feb 15, 2008 - 11...   Feb 16, 2008 - 7:33 AM
- - pabel89   what do you mean by detonation on the motor? what...   Feb 16, 2008 - 9:13 AM
|- - trd94   QUOTE(pabel89 @ Feb 16, 2008 - 9:13 ...   Feb 16, 2008 - 4:54 PM
- - mikecelica   just did a compression test done today and was 192...   Feb 16, 2008 - 7:06 PM
- - trd94   looks good to me, now i would make sure your timin...   Feb 17, 2008 - 9:00 AM
- - mikecelica   just had a quick question is it the 2nd gen 3sgte ...   Feb 20, 2008 - 11:28 AM
|- - presure2   QUOTE(mikecelica @ Feb 20, 2008 - 11...   Feb 20, 2008 - 11:37 AM
- - mikecelica   got it thanks/   Feb 20, 2008 - 11:47 AM
- - mikecelica   OK i think im finally done the buying process, ive...   Feb 22, 2008 - 11:31 PM
|- - jesterwr217   QUOTE(mikecelica @ Feb 22, 2008 - 11...   Feb 24, 2008 - 7:05 PM
- - mikecelica   bump   Feb 24, 2008 - 10:26 AM
- - mikecelica   anyone?   Feb 24, 2008 - 2:35 PM
- - CelicaST_CALI   remember to gap ur plugs a lil smaller after the t...   Feb 24, 2008 - 7:54 PM
Lo-Fi Version Time is now: August 31st, 2026 - 3:56 PM
