Feb 12, 2008 - 11:20 PM
Enthusiast ![]() ![]() ![]() Joined Jan 31, '07 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
Few questions i had about the 7AFTE setup:
1. Is a .45 trim t3 turbo ok size or too small? Lookng to make about 180hp or so 2. Is 3" exhaust too big, shud I go with 2 1/2? 3. Do i need an fmu if im gona use bigger injectors? thanks for any help This post has been edited by mikecelica: Feb 24, 2008 - 2:35 PM |
mikecelica 7AFTE Feb 12, 2008 - 11:20 PM
bccentaur3 That turbo size would be good for 180. I know its ... Feb 12, 2008 - 11:30 PM
mikecelica i got an safc2, so i shud go with 2.5" exhaus... Feb 13, 2008 - 12:06 AM
Celiracer18 go with 2.5" its best for a 7afte
plugs i th... Feb 13, 2008 - 1:01 PM
pabel89 you dont need an fmu if using bigger injectors i t... Feb 13, 2008 - 2:47 PM
mikecelica i do hav bigger injectors, i just got all my parts... Feb 13, 2008 - 4:01 PM
pabel89 no my car was choking because i didnt have it prop... Feb 13, 2008 - 4:14 PM
mikecelica ohh the injectors are off another 7afte so it shud... Feb 13, 2008 - 5:17 PM
pabel89 i have a .50 A/R compressor .63 A/R turbine. prett... Feb 13, 2008 - 5:54 PM
trd94 ok the probe injectors well work,but you well need... Feb 13, 2008 - 5:58 PM
pabel89 listen to trd94 he helped me alot when i was build... Feb 13, 2008 - 9:50 PM
mikecelica QUOTE(trd94 @ Feb 13, 2008 - 10:58 P... Feb 13, 2008 - 11:58 PM
mikecelica i dont realy understand this graph... What does it... Feb 14, 2008 - 12:22 AM
mikecelica bump Feb 14, 2008 - 4:46 PM
trd94 that is a small turbo. i have one that i used on m... Feb 14, 2008 - 6:16 PM
mikecelica i see... i still have some time now since my mecha... Feb 14, 2008 - 9:00 PM
trd94 it depends on when you want the power , at what rp... Feb 14, 2008 - 10:07 PM
normality78 hi trd94,
perhaps u may wanna let him know the hp ... Feb 14, 2008 - 11:08 PM
mikecelica i guess i'd be happy with 180hp... plus torque... Feb 14, 2008 - 11:20 PM
normality78 Actually this is what im facing now. Im still find... Feb 15, 2008 - 7:57 AM
pabel89 quick question about the 7afte, oil all around you... Feb 15, 2008 - 3:30 PM
trd94 QUOTE(pabel89 @ Feb 15, 2008 - 3:30 ... Feb 15, 2008 - 4:30 PM
trd94 most of my hp figures are on motor, and DD is Dail... Feb 15, 2008 - 4:25 PM
pabel89 idk why all that oil was in the turbo, i clean it ... Feb 15, 2008 - 4:42 PM
mikecelica got your car back from the mechanic? as in already... Feb 15, 2008 - 8:53 PM
mikecelica Plus i was wondering can i use the stock oil pan f... Feb 15, 2008 - 8:57 PM
trd94 QUOTE(mikecelica @ Feb 15, 2008 - 8... Feb 15, 2008 - 9:07 PM
trd94 the only reason i am did the rings and bearings is... Feb 15, 2008 - 9:12 PM
mikecelica I got about 105 miles on mine.. thing is i work at... Feb 15, 2008 - 9:14 PM
trd94 QUOTE(mikecelica @ Feb 15, 2008 - 9... Feb 15, 2008 - 9:27 PM
pabel89 no i been driving my 7afte for a month or so, no p... Feb 15, 2008 - 10:23 PM
trd94 QUOTE(pabel89 @ Feb 15, 2008 - 10:23... Feb 16, 2008 - 7:29 AM
mikecelica yeah i thought so too... alot of ppl i know said t... Feb 15, 2008 - 11:25 PM
trd94 QUOTE(mikecelica @ Feb 15, 2008 - 11... Feb 16, 2008 - 7:33 AM
pabel89 what do you mean by detonation on the motor?
what... Feb 16, 2008 - 9:13 AM
trd94 QUOTE(pabel89 @ Feb 16, 2008 - 9:13 ... Feb 16, 2008 - 4:54 PM
mikecelica just did a compression test done today and was 192... Feb 16, 2008 - 7:06 PM
trd94 looks good to me, now i would make sure your timin... Feb 17, 2008 - 9:00 AM
mikecelica just had a quick question is it the 2nd gen 3sgte ... Feb 20, 2008 - 11:28 AM
presure2 QUOTE(mikecelica @ Feb 20, 2008 - 11... Feb 20, 2008 - 11:37 AM
mikecelica got it thanks/ Feb 20, 2008 - 11:47 AM
mikecelica OK i think im finally done the buying process, ive... Feb 22, 2008 - 11:31 PM
jesterwr217 QUOTE(mikecelica @ Feb 22, 2008 - 11... Feb 24, 2008 - 7:05 PM
mikecelica bump Feb 24, 2008 - 10:26 AM
mikecelica anyone? Feb 24, 2008 - 2:35 PM
CelicaST_CALI remember to gap ur plugs a lil smaller after the t... Feb 24, 2008 - 7:54 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 3:54 PM |
