Feb 16, 2008 - 8:20 PM
Enthusiast Joined Jan 11, '08 From Tampa, Fl Currently Offline Reputation: 0 (0%) |
I'm rebuilding my 3s-gte and was condering where is the best place to buy a crankshaft. I have only been able to find remaned ones. Not sure aboout one of them. Just wondering what everyone is using.
Feb 17, 2008 - 10:42 AM
Enthusiast Joined Feb 17, '08 From Washington state Currently Offline Reputation: 0 (0%) |
Reconditioned should be fine , is there something wrong with your crank that it cant be reground? If it hasn't been reground to many times and the thrust surface is still within specs you should be able to get your crank turned by a local reputable machine shop and be installing it the next day. Should be cheaper to.
Feb 17, 2008 - 11:37 AM
What are you doing and how much are you spending?
If i were you, I would order a brand new OEM shortblock from toyota. You can get them for about 1500 bucks, with a 1yr warranty, and it will out last any rebuild. If you really just need a crank, I would also get a brand new OEM one. Ive seen a few people have issues with the regrinds. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 17, 2008 - 7:05 PM
okay I was wondering Cause nothing else is stock internally. Everything in upgraded. It spun a bearing once and wasted my turbo. I had it ground and just want to replace it this time. I doesnt have a spun bearing now but I noticed some flutering in the oil presure gauge and Stopped driving it. It was bought upgraded and i dont know how long ago so Ill feel better just rebuilding the whole thing. Ill check the local dealer hear and see what they run. Thanks again.
Feb 18, 2008 - 6:04 PM
Enthusiast ![]() Joined Feb 18, '08 From Kusel Deutschland Currently Offline Reputation: 0 (0%) |
check out alltrac.net i know they list alot of parts
| Lo-Fi Version | Time is now: July 12th, 2026 - 5:16 AM |
