Feb 19, 2008 - 10:51 AM
Then these would be the codes, and i need a code reader. I know some of the obd1 can use the jumper wire, but my car is different right? Thanks in advance.
P0100 Mass Air Flow Circuit. P0101 Mass Air Flow Circuit Range/Performance. P0105 Manifold Absolute Pressure Circuit. P0106 MAP/BARO Circuit Range/Performance. P0110 Intake Air Temperature Circuit. P0115 Engine Coolant Temperature Circuit. P0116 Engine Coolant Temperature Range/Performance. P0120 Throttle Pedal Sensor Switch "A" Circuit. P0121 Throttle Pedal Sensor Switch "A" Circuit Range/Performance. P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control. P0130 Heated Oxygen Sensor Circuit - Bank 1 Sensor 1. P0133 Heated Oxygen Sensor Circuit Slow Response Bank 1 Sensor 1. P0135 Heated Oxygen Sensor Circuit - Bank 1 Sensor 1. P0136 Heated Oxygen Sensor Circuit - Bank 1 Sensor 2. P0141 Heated Oxygen Sensor Circuit - Bank 1 Sensor 2. P0150 Heated Oxygen Sensor Circuit - Bank 2 Sensor 1. P0153 Heated Oxygen Sensor Circuit Slow Response Bank 2 Sensor 1. P0155 Heated Oxygen Sensor Circuit - Bank 2 Sensor 1. P0156 Heated Oxygen Sensor Circuit - Bank 2 Sensor 2. P0161 Heated Oxygen Sensor Circuit - Bank 2 Sensor 2. P0170 Fuel Trim malfunction. P0171 System too Lean. P0172 System too Rich. P0201 Injector Circuit - Cyl. 1. P0202 Injector Circuit - Cyl. 2. P0203 Injector Circuit - Cyl. 3. P0204 Injector Circuit - Cyl. 4. P0205 Injector Circuit - Cyl. 5. P0206 Injector Circuit - Cyl. 6. P0300 Random Misfire. P0301 Misfire Detected - Cyl. 1. P0302 Misfire Detected - Cyl. 2. P0303 Misfire Detected - Cyl. 3. P0304 Misfire Detected - Cyl. 4. P0305 Misfire Detected - Cyl. 5. P0306 Misfire Detected - Cyl. 6. P0325 Knock Sensor 1 Circuit. P0330 Knock Sensor 2 Circuit. P0335 Crankshaft Position Sensor "A" Circuit. P0336 Crankshaft Position Sensor "A" Circuit Range/Performance. P0340 CMP Sensor Circuit malfunction. P0385 Crankshaft Position Sensor "B" NE2 Circuit. P0401 EGR Flow Insufficient. P0402 EGR Flow Excessive. P0420 Catalyst System Efficiency below Threshold. P0430 Catalyst System Efficiency below Threshold Bank 2. P0440 EVAP Control System. P0441 EVAP Control System Improper Purge Flow. P0446 EVAP Control System Vent Control. P0450 EVAP Control System Pressure Sensor. P0451 EVAP Control System Pressure Sensor Range/Performance. P0500 Vehicle Speed Sensor. P0505 Idle Speed Control System. P0510 Close Throttle Position Switch. P1100 BARO Sensor Circuit. P1120 Accelerator Pedal Position Sensor Circuit. P1121 Accelerator Pedal Position Sensor Range/Performance Problem. P1125 Throttle Control Motor Circuit. P1126 Magnetic Clutch Circuit. P1127 ETCS Actuator Power Source Circuit. P1128 Throttle Control Motor Lock. P1129 Electric Throttle Control System. P1130 Air-Fuel Sensor Circuit Range/Performance. P1133 Air-Fuel Sensor Circuit Response. P1135 Air-Fuel Sensor Heater Circuit Response. P1150 A/F Sensor Circuit Range/Performance. P1153 A/F Sensor Circuit Response. P1155 A/F Sensor Heater Circuit. P1200 Fuel Pump Relay Circuit. P1300 Igniter Circuit - No. 1. P1310 Igniter Circuit - No. 2. P1335 No Crankshaft Position Sensor Signal - Engine Running. P1349 VVT System. P1400 Sub-Throttle Position Sensor. P1401 Sub-Throttle Position Sensor Range/Performance Problem. P1405 Turbo Pressure Sensor Circuit. P1406 Turbo Pressure Sensor Range/Performance Problem. P1410 EGR Valve Position Sensor Circuit. P1411 EGR Valve Position Sensor Circuit Range/Performance. P1500 Starter Signal Circuit. P1510 Boost Pressure Control Circuit. P1511 Boost Pressure Low. P1512 Boost Pressure High. P1520 Stop Lamp Switch Signal. P1565 Cruise Control Main Switch Circuit. P1600 ECM. P1605 Knock Control CPU. P1630 Traction Control System. P1633 ECM. P1652 Idle Air Control Valve Control Circuit. P1656 OCV Circuit. P1658 Wastegate Valve Control Circuit. P1661 EGR Circuit. P1662 EGR by-pass Valve Control Circuit. P1780 Park/Neutral Switch. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Feb 19, 2008 - 11:05 AM
Enthusiast ![]() Joined Jul 22, '07 From alexandria, VA Currently Offline Reputation: 0 (0%) |
Yea ive got a '97, theyre definity OBD II
I tried the jumper wire trick last week, but had no luck Im interested to know where i can get the right code reader too. -------------------- OBD-II makes me a sad panda
Feb 19, 2008 - 11:58 AM
Enthusiast ![]() Joined Mar 17, '04 From Lansing, MI Currently Offline Reputation: 0 (0%) |
96+ is OBDII
You can go to any autozone and have them come out to your car and run their scan tool to see the CEL codes for free. |
Feb 19, 2008 - 2:58 PM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
QUOTE(mike96ST @ Feb 19, 2008 - 4:58 PM) [snapback]643205[/snapback] 96+ is OBDII I think it depends on territory. I am 99% sure that 96+ for the UK market are still OBD I. -------------------- Davey
Items for sale |
Feb 19, 2008 - 4:32 PM
http://www.amazon.com/Actron-CP9175-AutoSc...6675&sr=8-1
http://www.amazon.com/Actron-CP9135-AutoSc...6675&sr=8-3 one of these two..... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Feb 19, 2008 - 7:47 PM
you have ALL of those codes?
Feb 19, 2008 - 9:59 PM
QUOTE(Bitter @ Feb 19, 2008 - 7:47 PM) [snapback]643398[/snapback] you have ALL of those codes? my other car has the 71, but it applies to my celi... since both are obd2 im getting a reader... if i had all those codes, i will be crying.... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Feb 21, 2008 - 9:30 AM
"Im a toyota engine dammit, i dont need silly spark plugs, injectors, or even an ecu, i can run on hopes and dreams!!" -------------------- OBD-II makes me a sad panda
Feb 21, 2008 - 10:04 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
QUOTE(BloodyStupidDavey @ Feb 19, 2008 - 2:58 PM) [snapback]643272[/snapback] QUOTE(mike96ST @ Feb 19, 2008 - 4:58 PM) [snapback]643205[/snapback] 96+ is OBDII I think it depends on territory. I am 99% sure that 96+ for the UK market are still OBD I. Only US spec cars [and Canadian/Mexican market by default] have OBD II. It's a US govt requirement. -------------------- ![]() |
| Lo-Fi Version | Time is now: September 16th, 2026 - 3:34 AM |
