Feb 23, 2008 - 1:12 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
So I got my injectors back from witchhunter and they were tested and cleaned by them. So I get it back and looked at the chart, and although the injectors were dirty to begine with only one of them was fair. I looked at the numbers and aren't the injectors supposed to be 315's? I sent them the supra na injectors green top. The numbers came back and it said that they were flowing like 124 or something. Can someone fill me with some info. I'm a bit confused at the moment.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Feb 23, 2008 - 6:38 PM
QUOTE(bccentaur3 @ Feb 23, 2008 - 1:12 AM) [snapback]644815[/snapback] So I got my injectors back from witchhunter and they were tested and cleaned by them. So I get it back and looked at the chart, and although the injectors were dirty to begine with only one of them was fair. I looked at the numbers and aren't the injectors supposed to be 315's? I sent them the supra na injectors green top. The numbers came back and it said that they were flowing like 124 or something. Can someone fill me with some info. I'm a bit confused at the moment. can you post the pic? if your planning on using them (the 315's) for a 5sfte, i wouldnt. its been dyno proven that you will run dangerously lean with them under boost. as lean as 17:1 -------------------- Former Team 5SFTE pro member ;)
Feb 23, 2008 - 10:24 PM
Okay they were being tested at 43.5 psi. And the flow rate was more like 129. Yes, I am planning on running them on my 5sfte project. So I'd go as lean even at factory boost? I wouldn't be able to run these for maybe a couple of weeks?
Feb 23, 2008 - 11:42 PM
QUOTE(bccentaur3 @ Feb 23, 2008 - 10:24 PM) [snapback]645043[/snapback] Okay they were being tested at 43.5 psi. And the flow rate was more like 129. Yes, I am planning on running them on my 5sfte project. So I'd go as lean even at factory boost? I wouldn't be able to run these for maybe a couple of weeks? i ran them for a couple months at 9 or so PSI, but i wouldnt recommend them to anyone else. its just plain dangerous. -------------------- Former Team 5SFTE pro member ;)
Feb 24, 2008 - 12:13 AM
Alright Manny, I have just taken your advice and picked up CaliJeff's injectors and neo.
| Lo-Fi Version | Time is now: August 31st, 2026 - 9:08 PM |
