> 7afte help, MODS please move!!!
post Feb 23, 2008 - 5:50 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
hey all.
as some of you know i started my turbo build.
Anyway, so far manifold has been done and turbo (T25) mounted. Oil filter relocation kit fitted and a few other bits.
One thing my friend mentioned was the two hoses between the cam cover and the inlet manifold. Do these need to be blocked or have they got one one way valves?
Intercooler will go on Monday and fuel pump. Please advise what to do about vacuum pipes.
Cheers.
This post has been edited by FunkySR: Mar 7, 2008 - 8:21 PM
Replies (1 - 12)
post Feb 23, 2008 - 6:32 PM
im not the 7afte expert, but, my first thought is to say, if i remember right, the 7a has 2 hoses, one with the PCV valve, and one without.
the once with the PCV valve "should" be able to stay, as the PCV valve is a one way valve, that will only allow crankcase vapors to be evacuated by intake manifold vacume.
the other hose should be routed to your intake piping, pre- turbo, with a catch can in line with that if you choose to use one.
lookin good BTW!
post Feb 23, 2008 - 9:21 PM
trd94
Joined Jan 9, '05
From green springs ohio
presure2 is right with the vacuum hoses , if you leave it hooked up it will cause your valve cover seal to blow ,and i would try to use a catch can.
This post has been edited by trd94: Feb 23, 2008 - 9:22 PM
post Feb 24, 2008 - 5:04 AM
FunkySR
Joined Apr 22, '07
ok people thanks.
post Feb 24, 2008 - 9:50 PM
nice.
did you need to relocate the oil filter ? I have seen other 7aftes and they haven't relocated it, is it in the way with the downpipe ?
post Feb 25, 2008 - 2:27 AM
FunkySR
Joined Apr 22, '07
in all fairness i wanted an easy life and quick oil changes. I think It will be in te way, but we'll see how fabricating the downpipe goes...I would be gutted if I had to keep the filter there. I like being different. haha.
post Feb 26, 2008 - 6:13 PM
FunkySR
Joined Apr 22, '07
hey all.
Custom downpipe done. 2.5 inch all the way.
post Feb 26, 2008 - 11:21 PM
beauty
post Feb 26, 2008 - 11:24 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Nice work, what are you using to control your fuel injectors?
94 Celica gt white (sold)
post Feb 27, 2008 - 12:38 PM
FunkySR
Joined Apr 22, '07
for now I have an SAFC 2 installed buit will be upgrading to GReddy in the very near future.
post Mar 6, 2008 - 12:25 AM
I've been following the progress on the ccuk, why did you have to delete the oil filter relocation kit ?
no room for it ?
no place to mount it ?
was there enough room with the filter as is ?
post Mar 6, 2008 - 3:10 PM
Insanity-74
Joined Jan 9, '05
From Under the car
That exhaust manifold looks like its made from cast water pipes????????
post Mar 7, 2008 - 8:20 PM
FunkySR
Joined Apr 22, '07
QUOTE(Batman722 @ Mar 6, 2008 - 5:25 AM) [snapback]649713[/snapback]
no room for it ?
yes, there was no room dude. but the filter is cool where it is now.
QUOTE(Insanity-74 @ Mar 6, 2008 - 8:10 PM) [snapback]649938[/snapback]
it's a JSG Tools manifold dude. The Honda tubular manifold would have lost me my air con...couldnt have that. ha ha
I couldnt find this thread and started a new one. oops...hope management wont slap my wrists.
Lo-Fi Version Time is now: August 23rd, 2026 - 6:56 PM
