Feb 24, 2008 - 2:22 PM
Enthusiast ![]() Joined Feb 21, '08 From Saint John, NB Currently Offline Reputation: 0 (0%) |
my abs light has been on since i'v owned the car so today i figured i would see what was the problem, so i did some searching on here and found out how to check the code, well i did what they said TC and E1 and all that did was make my cruise control and airbag lights flashes repeatedly and my abs light stayed on constantly, then i decided to check my engine codes just for ****s and giggles and got a 25 code from that :S anyone know the proper way of check the abs codes? or am i just missing a step?
-------------------- 94 Celica GT Hatchback 5spd
89 Nissan 240sx coupe 5spd -RIP 87 BMW 325 2dr 5spd - SOLD- Gone but never forgotten |
Feb 24, 2008 - 3:38 PM
hrrrmm. That might be for US only, I'll have to check that out.
code 25 is for the 02 sensor, also for the E1 circuit open. Pull the EFI fuse, wait 30 seconds then reinstall it. The code should be gone. -------------------- |
Feb 24, 2008 - 10:13 PM
kk i'll try that with the o2 sensor, i have a small exhaust leak around my flex pipe so thats probably whats setting that code off but as for the abs i'm still puzzled
Feb 25, 2008 - 8:10 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
If your ABS light stays steady when you jump the terminals the ABS ECU is probably bad....
Try resetting it and see what happens. You can clear all codes by jumping Tc and E1 with the key on. With it jumped press the brake pedal 8+ times in 3 seconds or less. Or you can disconnect the battery [or just pull the fuse]. Physically removing power will completely reset the ECU and MIGHT solve the problem. *Did you pull the short pin out of the diag box before you jumped the terminals? Its in the furthest corner from the "hinge" on the cover of the diag box.* -------------------- ![]() |
Feb 25, 2008 - 10:34 PM
theres a pin u need to remove???? didnt know that :S hmm might have to try that tomorrow
Feb 27, 2008 - 5:35 PM
Download the celica manual, it'll tell you everything you need to know.
http://www.griffindesignco.com/6gc/electri...ng_diagrams.zip http://www.griffindesignco.com/6gc/fullmanual.zip and for a fast and easy shortcut to the codes page only, http://www.griffindesignco.com/6gc/2_2LCodes.pdf -------------------- ![]() |
Mar 7, 2008 - 7:47 PM
Enthusiast ![]() Joined Feb 4, '08 From UK Currently Offline Reputation: 0 (0%) |
Try putting a voltemeter accross the sensor loom in the wheel arch and determine which ABS sensor has failled, and then replace it!
This post has been edited by 94TRDcelica: Mar 7, 2008 - 7:48 PM -------------------- ![]() |
Mar 8, 2008 - 5:29 PM
yeah i might be throwing my 17's on soon so when i pull the winters off i'll do that
Mar 9, 2008 - 3:23 PM
alright i decided to go take a look for those codes again, i pulled the pin this time and i got 31,32,33,34,35,36 for codes :S
Mar 9, 2008 - 4:13 PM
ok i figured out what the codes are for but, there must be a reason for ALL of them to be on...faulty abs module? i'm gonna have to do some digging to get to the bottom of this one
Mar 9, 2008 - 6:14 PM
Check the relay for the ABS ECU! Check all fittings and simply check the resistance accross the senders by removing the wheel, disconnecting the sensor loom and putting a voltage meter accross the terminals and get a second person to spin the disc. You should be able to read something, if not replace the sender!
Other than that like I said could be a realy, check all fuses. Also disconnect the battery for 5mins and then reconnect and test again for codes! GL - and post your findings!!!!! -------------------- ![]() |
Mar 10, 2008 - 4:17 PM
Bad wheel speed sensor is my guess
Mar 10, 2008 - 5:22 PM
All 4 wheel speed sensors....
Is anything disconnected? If you check the sensors with a multimeter, use AC volts, not DC. You can also check resistance, it should be somewhere around 1 - 2 ohms. -------------------- ![]() |
Mar 10, 2008 - 9:05 PM
i just find it odd that all 4 are reading and plus code 35 and 36 , i havent got a chance to take a look at it yet but eventually i will make my way to the garage
Mar 10, 2008 - 9:38 PM
35 and 36 are just front speed sensor and rear speed sensor [either side]. The other 4 are for each of the individual sensors.
So all 6 are for your speed sensors. -------------------- ![]() |
Mar 11, 2008 - 4:47 AM
Mar 11, 2008 - 6:57 PM
oooooooooh lol so it is possible for all for speed sensors to be fried at the same time? :S thats crazy well i will take a peak at them this weekend and report my findings. thanks for all the advice
Mar 11, 2008 - 7:55 PM
It's possible, but unlikely.
Something else is more likely the problem. You might want to reset the ECU and see if these come back. -------------------- ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 8:36 PM |
