Feb 25, 2008 - 11:30 PM
![]() Enthusiast ![]() Joined Mar 26, '05 From Snohomish, WA. Currently Offline Reputation: 0 (0%) |
A while back my air bags were deployed, and other than the obvious fix (taking out the light in the gauge cluster), is there any other way to make the light go out. I'm not planning on having the air bags recharged or anything along those lines.
thanks. -------------------- You only live once...
Feb 25, 2008 - 11:33 PM
![]() Enthusiast ![]() ![]() Joined Feb 20, '08 From Abingdon, Maryland Currently Offline Reputation: 7 (100%) |
i believe you need a certian type of computer hooked up to your car to detect the airbag error number and delete it for the light to shut off.
Feb 25, 2008 - 11:39 PM
Enthusiast ![]() ![]() Joined May 1, '03 From Houston , Texas Currently Offline Reputation: 4 (100%) |
take your celica to toyota for an oil change and walk back to the mechanic and ask him to delete it for you. We did it for people at honda all the time.
- Matt |
Feb 26, 2008 - 12:16 AM
![]() ![]() It does work but it's tricky. good luck -------------------- |
Feb 26, 2008 - 11:57 AM
check state laws there, if you have a clean title on your car, I think it's against the law to conceal that your airbags have deployed. In fact it might be against the law regardless of title status. I think you have to disclose it either way. (in Oregon you do)
Feb 26, 2008 - 12:00 PM
Enthusiast ![]() Joined Jul 16, '05 From Vancouver, BC Area Currently Offline Reputation: 2 (100%) |
QUOTE(GriffGirl @ Feb 26, 2008 - 8:57 AM) [snapback]646005[/snapback] check state laws there, if you have a clean title on your car, I think it's against the law to conceal that your airbags have deployed. In fact it might be against the law regardless of title status. I think you have to disclose it either way. (in Oregon you do) Just disconnect the cable from the air bag control unit. It's under the armrest. |
Feb 26, 2008 - 12:19 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
i know with my dsm's you needed to put a 2ohm resistor i beleive in place of the air bag or the light would stay on. I did this on one with the drivers airbag still in, but pulled the passenger's to save weight... what a joke i know
i later just took the whole system out -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Feb 26, 2008 - 10:11 PM
QUOTE(djyohimbe @ Feb 26, 2008 - 9:00 AM) [snapback]646007[/snapback] QUOTE(GriffGirl @ Feb 26, 2008 - 8:57 AM) [snapback]646005[/snapback] check state laws there, if you have a clean title on your car, I think it's against the law to conceal that your airbags have deployed. In fact it might be against the law regardless of title status. I think you have to disclose it either way. (in Oregon you do) Just disconnect the cable from the air bag control unit. It's under the armrest. that box under the arm rest (center console) is the control unit and all i have to do is disconnect. -------------------- You only live once...
Mar 4, 2008 - 10:04 AM
Enthusiast ![]() Joined Jan 6, '08 From Oak Ridge TN Currently Offline Reputation: 1 (100%) |
Not to thread jack or anything, but I have the same issue, execpt my airbags have been repacked and recharged. Can't you just take an OBD2 scanner and clear the codes?
-------------------- If anyone needs info on the Toyota Curren feel free to PM me!
Mar 4, 2008 - 3:35 PM
Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
this is by far your easiest solution man. there is an airbag fuse in the engine bay fuse box... pull it.
lol its what i did after my wreck, fixing them is just too pricey. -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
Mar 4, 2008 - 5:26 PM
QUOTE(Batman722 @ Feb 26, 2008 - 12:16 AM) [snapback]645842[/snapback] ![]() It does work but it's tricky. good luck have any of even tried to do this ? -------------------- |
Mar 4, 2008 - 10:31 PM
Enthusiast ![]() ![]() ![]() Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
I was gonna try it but, was told that my airbags may deploy under hard braking if the code that was popping up for mine was correct(have the code saying the sensors are bad, i know it was in an accident and know that the airbags were replaced but not sure if they just didn't reset the system or if the sensors are really bad) and not just a lazy person not resetting my system after it was wrecked.
Mar 4, 2008 - 11:09 PM
QUOTE(needforspeed @ Feb 26, 2008 - 7:11 PM) [snapback]646281[/snapback] QUOTE(djyohimbe @ Feb 26, 2008 - 9:00 AM) [snapback]646007[/snapback] QUOTE(GriffGirl @ Feb 26, 2008 - 8:57 AM) [snapback]646005[/snapback] check state laws there, if you have a clean title on your car, I think it's against the law to conceal that your airbags have deployed. In fact it might be against the law regardless of title status. I think you have to disclose it either way. (in Oregon you do) Just disconnect the cable from the air bag control unit. It's under the armrest. that box under the arm rest (center console) is the control unit and all i have to do is disconnect. That's what I did...it severs the power to the airbags and the light goes off. |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 12:11 PM |
