> car boggy out at 6k
post Feb 27, 2008 - 3:30 PM
stocky
Joined Feb 27, '08
From miltown
well im new to this site. so was woundering if anyone would know why my car would bogg out at 6k rpm when i step on the gas in all gears. i have the 2 bar map sensor, and the frount mount intercooler and bov hooked up correctly basicly everything that makes the car runnin correctly mostly all the supports. the car is running great but the thing is just that when i push the car to the max i bogg out.. i have the ecu chipped to 8200 rpm but only went up to that like twice. anyone know anything that would cause the problem please let me know.
This post has been edited by stocky: Feb 27, 2008 - 3:52 PM
post Feb 27, 2008 - 3:57 PM
What is your setup? How much boost?
post Feb 27, 2008 - 4:23 PM
DEATH
Joined Dec 19, '07
From tx
Stock 3S fuel pump? Stock 5S fuel pump?
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Feb 27, 2008 - 4:28 PM
stocky
Joined Feb 27, '08
From miltown
im only currenty doing 9psi. i have a 3rd gen swap i have a artist automotive chip ecu. warblo 255 fuel pump hks cams and jerrys valves. i have 660 injectors and aem fuel rail with the reguator... also i have the apexi afc hooked up. soo yeah thats about it the engine is also ported or the head is. the car hasnt been tune yet but what ive seen while driving is when i floor the beast i boggs out as soon as i hit 6k but but if i do it again and lay off the gas it seems to pull all the way till 8200 rpm..any clue?
im going to pull out the fuel pump again. later today cuz while i was lookin around the forms. i saw a post about which warblo to get or the right one to get for out type of car.
post Feb 27, 2008 - 4:58 PM
Did you buy the car already moded? What turbo are you on?
If your still on the stock ct20b, then there is no reason to have 660 injectors in there. You are probably bogging out and loosing power from way too much fuel. You should put the stock 550s in there and get the car on a dyno.
post Feb 27, 2008 - 5:17 PM
stocky
Joined Feb 27, '08
From miltown
no i swapped the car out my self i have a bored out ct20 in there just waiting to put in the hks 38gtr in i have those just for cause the 550 was messed up and wasnt useable anymore but i still dont understand why the freaken car boggs out. evrything is right well lets just see and let me put in the mr2 550 injectors in and see.. but do u think the fuel pump has anything to do with it?? like what death said im worry now about that too. ooh yeah bored out meaning that the turbo was rebuild and had new finns put in which it spools at like 2500 rpm and keeps up till like 7200 dont know how it works but it holds boost and flys till 7200..tried it on my buddy mr2 almost blew his motor too haha..
This post has been edited by stocky: Feb 27, 2008 - 5:19 PM
post Feb 27, 2008 - 5:34 PM
You really need to either buy a wideband or get the car on a dyno. That will tell you whats really going on.
But you have 2 obvious problems...
1. you cant just put in bigger injectors on an ecu thats programed for smaller ones. the whole car will loose power and not run correctly. An SAFC is not a proper way to tune for bigger injectors either.
2. If your still on the stock fuel pump, you should get a walbro.
If i were you, i would put the stock 550s in there. 550s are enough for about 360whp worth of fuel and thats way more then you can make from the ct20b.
Then when your ready to upgrade the turbo, I would sell your stock ecu, ct20b and safc and use that money to buy a powerFC or AEM standalone.
This post has been edited by lagos: Feb 27, 2008 - 5:43 PM
post Feb 27, 2008 - 5:40 PM
stocky
Joined Feb 27, '08
From miltown
thanks lagos im guessing your the 3sgte guru of the 6gen forms huh..nice that i have met u but yeah ill do that kk il let yah know after i try out the tips...
post Feb 27, 2008 - 5:44 PM
no prob. post some pics of your car/setup !
post Feb 29, 2008 - 3:47 PM
stocky
Joined Feb 27, '08
From miltown
oh i will just need to clean up the engine bay and get everything shiny and stuff then.. yah will see....smile.gif
post Feb 29, 2008 - 3:56 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(stocky @ Feb 27, 2008 - 6:28 PM) [snapback]646612[/snapback]
then why are you trying to rev to 8k... check your timing, and get a new fuel fiter if your using an old one.
post Feb 29, 2008 - 9:52 PM
stocky
Joined Feb 27, '08
From miltown
did it a couple times alrdy when the car first got to runnin..but as u know one day it just started to bogg out at 6k so yeah.. but bad news alrdy today got new fuel pump and filter car runs perfect..it was the fuel pump i got a defected one for the tuner store closes by..so i got a new one for free and they install it for free just cuz the f up...car revs up to 8200 now but i dear not go that high yet. buz the car isnt tuned ill stay awway for a bit..
bad new frown.gif while driving the car home i kinda broke my right side axle great huh..need to replace then will post photos of the car...
post Feb 29, 2008 - 11:11 PM
Just remember... just because you dont have a rev limiter, doesnt mean you can/should rev to 8k. Those shims can fly out at high rpm's causing all sorts of problems.
post Mar 1, 2008 - 12:34 AM
stocky
Joined Feb 27, '08
From miltown
i think i just broke my axle today because of that. where could i get aftermarket axles? let me know, thanks!
Lo-Fi Version Time is now: September 2nd, 2026 - 6:55 AM
