> Possible clutch slipping
post Feb 27, 2008 - 6:30 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
For about the past 2-3 months my car has been doing this. It only happens in the morning or when the car is cold. After that it will never happen again (until the next day).
I release the clutch (not all the way), and the car will begin to roll. When I press the gas pedal the car stutters. If I push the clutch back in it stops, when released to start going again it starts. So, is this a problem with my clutch? Or do you think my flywheel needs to be resurfaced?
Also, I have always had a problem getting the car into reverse. It will go half way but not all the way. If I release the clutch a little less than half, it will fall right into gear. This recently started happening to me when trying to put the car into first gear and I have to do the exact same thing to get it in, releaes the clutch a little and it falls right in.
Lo-Fi Version Time is now: August 25th, 2026 - 11:20 AM
