> HELP!!!!!!!!, one of those overheating problems
post Feb 28, 2008 - 8:17 PM
Theshanon
Joined Jan 9, '08
From Scarborough, Ont
Sorry guys i tried to search but nothing came up!!
ANYWAYS, so my car is infact over heating.
First week i noticed this- K!!! so about a week ago my temp gauge started acting up....it would rise..then when i turn my heater on it would drop. Couple days later my heater would no longer work, so i checked my coolant and barley had anything left so i topped it up. Everything seemed fine for a bit, then a day or two after my temp gauge reach above 'H' and i pulled over and it sounded like my head was boiling a nice pot of soup. I waited a bit and quickly released the rad cap. It steemed for a bit (obviously) and i toped it off with coolant and it ran fine for a day or two. So today on my way to work i ended on heading back home on a flat bed. My temp gauge stayed at above 'H', no warm air....i topped it of with coolant, and i donno where it goes :| its hard for me to tell if theres a leak...and i hope its not my head gasket?
- Theshanon   HELP!!!!!!!!   Feb 28, 2008 - 8:17 PM
- - Jeunesse   Is your radiator fan working alrigt? what about th...   Feb 28, 2008 - 8:21 PM
- - Theshanon   thats what i thought hmmmm i'll go check right...   Feb 28, 2008 - 8:25 PM
- - Havok1997GT   check for leaks. hoses, Rad and water pump. tho...   Feb 28, 2008 - 8:27 PM
- - Jeunesse   Not tonight and tomorrow coz its my turn to babysi...   Feb 28, 2008 - 8:29 PM
- - politicsareevil   You've definately got a leak somewhere.. You s...   Feb 28, 2008 - 8:31 PM
- - Theshanon   haha thank i was just kidding though, its late and...   Feb 28, 2008 - 8:34 PM
|- - Jeunesse   QUOTE(Theshanon @ Feb 28, 2008 - 8:3...   Feb 28, 2008 - 8:40 PM
- - Batman722   first, you killed the thermostat, that needs to be...   Feb 28, 2008 - 8:43 PM
- - politicsareevil   Lets hope you didnt blow your head gasket but yeah...   Feb 28, 2008 - 8:46 PM
- - pabel89   you should replace your radiator, or thier a littl...   Feb 28, 2008 - 8:53 PM
|- - Theshanon   QUOTE(pabel89 @ Feb 28, 2008 - 8:53 ...   Feb 28, 2008 - 8:59 PM
- - politicsareevil   Is the radiator leaking..... Go to your local auto...   Feb 28, 2008 - 8:57 PM
- - politicsareevil   About 20-45$ depending. Its pretty sweet. It ...   Feb 28, 2008 - 9:06 PM
- - scothaniel   Another way to test the radiator fan - unplug the ...   Feb 29, 2008 - 2:50 PM
|- - Theshanon   QUOTE(scothaniel @ Feb 29, 2008 - 2...   Mar 1, 2008 - 2:39 AM
- - alltracman78   Shanon? You need to take a step back here, there...   Feb 29, 2008 - 8:43 PM
- - Jeunesse   Hey Shanon, were you able to get your car fixed? W...   Mar 1, 2008 - 12:47 AM
- - Theshanon   well i removed the old thermostat and tested it......   Mar 1, 2008 - 1:53 AM
|- - politicsareevil   QUOTE(Theshanon @ Mar 1, 2008 - 12:5...   Mar 1, 2008 - 2:54 AM
- - alltracman78   QUOTE(politicsareevil @ Mar 1, 2008 - 2...   Mar 1, 2008 - 1:12 PM
- - dabazied   QUOTEQUOTE(politicsareevil @ Mar 1, 2008 - 2:54 AM...   Mar 1, 2008 - 1:19 PM
- - Theshanon   thermostats here, with empyolee discount go for 30...   Mar 1, 2008 - 5:18 PM
- - alltracman78   If the fan runs with the fan switch disconnected b...   Mar 1, 2008 - 7:08 PM
- - Theshanon   it enever got past the middle, i took it out for a...   Mar 2, 2008 - 3:29 PM
- - alltracman78   If it's real cold the fan won't necessaril...   Mar 2, 2008 - 9:03 PM
- - scothaniel   With the temps below 40F in Michigan, I dont think...   Mar 3, 2008 - 5:43 PM
- - Theshanon   this is still weird man, my gauge hits the red H z...   Mar 5, 2008 - 5:15 PM
|- - alltracman78   QUOTE(Theshanon @ Mar 5, 2008 - 5:15...   Mar 5, 2008 - 8:17 PM
|- - Theshanon   anyways... QUOTE(alltracman78 @ Mar 5, 2008 ...   Mar 6, 2008 - 1:47 AM
- - stephen_lee   still does that even after you replaced the therm?...   Mar 5, 2008 - 5:37 PM
- - Theshanon   i loose coolant but i don't see it going anywh...   Mar 5, 2008 - 5:39 PM
|- - alltracman78   QUOTE(Theshanon @ Mar 5, 2008 - 5:39...   Mar 6, 2008 - 9:56 PM
- - stephen_lee   it just corroded out. you'd know if it was tha...   Mar 5, 2008 - 5:56 PM
- - Batman722   QUOTE(Batman722 @ Feb 28, 2008 - 8:4...   Mar 5, 2008 - 8:57 PM
- - Theshanon   listen bat bwoiiiiiii i appreciate your time and a...   Mar 5, 2008 - 9:39 PM
- - Batman722   what's a "bwoiiiiiii" ?   Mar 6, 2008 - 12:29 AM
- - scothaniel   Any funny smell or coloration in the exhaust? If ...   Mar 6, 2008 - 11:33 AM
- - GriffGirl   I always try the super simple stuff first - you al...   Mar 6, 2008 - 2:10 PM
- - mahem109   Hey all, I have a 95 gt, 5fse, and guess what? it ...   Jul 18, 2008 - 9:02 PM
- - Toyotacelicafan1   I am going to try and add my input a little bit fr...   Jul 20, 2008 - 1:00 AM
Lo-Fi Version Time is now: August 28th, 2026 - 3:53 AM
