> seafoamed but.., tick worsened? advice..
post Mar 6, 2008 - 12:27 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
so just got finished "seafoam-ing" the engine and it was smoking pretty good as expected and the engine was hating life for a few minutes but all said and done it seems like the slight tick i had has maybe just gotten worse? so do i continue to use? give it some time to go away? i am pretty sure i need a new valve cover gasket but i don't think that would cause the tick to be more severe...? really i am in no rush b/c i just need this 7a to make it a lil longer till i swap in a 3s this summer... suggestions welcomed though.
Replies (1 - 5)
post Mar 6, 2008 - 12:57 PM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
QUOTE(cjh4l22 @ Mar 6, 2008 - 12:27 PM) [snapback]649853[/snapback]
if you run it through the oil it will thin it out and would probably make a tick like that louder, i would give it some fresh oil now.
post Mar 6, 2008 - 1:25 PM
Take off the valve cover and check your valve shim clearances. Im willing to bet thats whats making the noise.
post Mar 6, 2008 - 2:05 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
time for an oil change too
post Mar 6, 2008 - 10:01 PM
alltracman78
Joined Aug 9, '06
From Ma
Did you seafoam the engine oil or just the intake?
FYI Toyota engines tick. It's part of owning a Toyota.....
*Not to say you don't have a problem, but sometimes a "problem" is par for the course*
post Mar 7, 2008 - 4:35 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
completed oil change, didn't notice if it were better/worse today...
QUOTE(lagos @ Mar 6, 2008 - 1:25 PM) [snapback]649883[/snapback]
ha sorry not happening but thanks for the advice.
QUOTE(alltracman78 @ Mar 6, 2008 - 10:01 PM) [snapback]650121[/snapback]
and i put a small amount (maybe.. an ounce) in the oil (before the change). and about 1/3 the bottle in the intake. i used about 2oz in my brothers camry and the rest will be going on my gas soon.
ha thanks alltracman and everyone else.
Lo-Fi Version Time is now: August 23rd, 2026 - 9:33 PM
