> Boring the 5sfe, can it be done safely
post Mar 6, 2008 - 4:49 PM
6G96GT
Joined Jan 20, '08
From East Coast
Can I have the cylinders bored on the 5sfe? I heard the cyl-walls are too thin to get it done and would be prone to cracking. True??
Also, what components do I want to get after the full rebuild? Radiator? Hoses? Water Pump...what else???
One more thing...webcams (is it really worth it, I mean with a short ram air intake, stock header, and performance exhaust, what gains am I looking at for HP with the webcams and shouldn't I get a port/polish on the head for better breathability for the webcams??)...how much and what's the address I have to send them to? Thanks!
This post has been edited by 6G96GT: Mar 6, 2008 - 4:51 PM
Replies (1 - 11)
post Mar 24, 2008 - 12:31 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
Yep, you're correct. You can't bore the 5sfe because the walls ARE too thin.
I'll leave it to the pro's to tell you what you'll need after a rebuild.
But as for the webcams camshafts, it's worth it ONLY IF you decide to stick with your 5sfe motor, if not, then don't even bother and just do a 3s swap, because it'll cost like 6-700 to have them regrind your cams, and your car will have downtime as you have to take ur cams out to send to them unless you buy a spare set.
However, it's quite worth it if u decide to stay with ur 5s motor because it's like a 20hp increase (there's a thread all about it) and it'll give that constant power in ur 3rd gear all the way to redline and past.
Also for the port/polish on the head, it'll cost you like ~200 and once again, IF U DECIDE to stay with ur 5s motor and eventually do the 5sfte will be the only way you'll get some more serious power gains.
I can't remember the address to Webcams, but im sure its somewhere in one of the threads, or search on the parts database for the website and collect the contact info.
post Mar 24, 2008 - 4:49 PM
6G96GT
Joined Jan 20, '08
From East Coast
Thanks, appreciate the info!
post Mar 27, 2008 - 8:21 AM
Kerr1
Joined Dec 24, '06
From jonesville
i had mine bored .040 over and its doin fine...i rip on it a lot too
post Mar 27, 2008 - 9:21 AM
D-Man
Joined Jan 18, '08
From Houston
yeah, i wanted to but it's just not a good idea...
Damn D-Man - most impressive.
post Apr 6, 2008 - 4:13 PM
6G96GT
Joined Jan 20, '08
From East Coast
So it seems like .020 is ok right...but .040 isn't but it worked for Kerr1...so I was wondering about that...I saw a performance engine block for a 5sfe where it was bored to .040 and they installed ROSS Forged Pistons (10.5-1 comp ratio). It seemed ok for those guys...just wondering.
post Apr 6, 2008 - 4:48 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
just finished my rebuild. bored mine to .030, fine here also.
check out my list for my rebuild, you might wanna start there...
http://www.6gc.net/forums/index.php?showtopic=55662&st=0
This post has been edited by nightryder: Apr 6, 2008 - 4:56 PM
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Apr 6, 2008 - 5:20 PM
6G96GT
Joined Jan 20, '08
From East Coast
QUOTE(nightryder @ Apr 6, 2008 - 4:48 PM) [snapback]661937[/snapback]
I was just reading your post on that...cool. Anyway what pistons did you get? Did you use stock rods? Is our crank forged from the factory? Cool project man, looks great...sorry she died on you though, I know how that feels. Could you include some engine bay pics?
post Apr 6, 2008 - 5:30 PM
alltracman78
Joined Aug 9, '06
From Ma
You're most likely fine boring the block.
To what exact point I couldn't tell you.
The block cracking is mainly for those seeking very high HP.
As far as what is forged, the crank is, as well as most likely the rods and pistons.
Forging is normal for OEM parts. Has been since the 90s.
post Apr 6, 2008 - 5:43 PM
Kerr1
Joined Dec 24, '06
From jonesville
as far as i kno the pistons are cast... the rods are forged, but not very strong.. the crank is forged too and supposedly its a beast...very strong from the factory.
post Apr 7, 2008 - 7:38 AM
Terracar
Joined Mar 28, '08
From Washignton
5s cranks are forged - and beastly! (they are used in 3s strokers)
pistons/rods should be upgraded if going for high power #s, though it is up to you and the budget
-Terra
'92 ST185, '88 ST165, '05 Galant LS, '08 Legacy
post Apr 7, 2008 - 1:08 PM
nightryder
Joined Sep 29, '05
I have to get into contact with my machinist, he has all the info on the pistons and whatnot. I did replace the rods tho...
the rods are def the weak point of the bottoms end, if you are worried about something busting on you, worry about the rods...
Crank is forged (and beastly...yes) i had mine machined down and had oversized bearings installed.
Lo-Fi Version Time is now: September 18th, 2026 - 8:33 PM
