Mar 9, 2008 - 5:20 PM
So, i really dont need my gauges any more now that i have my AFC Neo, so im gonna get rid of them.
They are Stewart Warner gauges, black face with silver bezzel. There is a Volt, A/F, and Electric Oil Pressure. They are just basic connection 4 or 5 connection. The gauges use a 194 bulb and i have a set of PIAA 194 LED white bulbs in it. Extreamly bright very white bulbs. They are all held in a LoTek 3 gauge pillar pod. Instead of using the big screws that the Lotek pods come with, i drilled out the holes and im using the little clips used from autometer gauge pods. I also used Russel fittings for the oil pressure sending unit to hook up inline off a sandwich plate. I never did install the oil pressure gauge fully. NOT SEPERATING GAUGES AND POD. Pictures ![]() Sending unit with russel fittings ![]() ![]() ![]() Lit up ![]() Im asking $230CND + shipping for all the gauges, oil sending unit and fittings And im also selling a FlexALite Oil cooler. I had this installed when i had some issues with my oil gettin to hot due to exhaust. It works great, but i no longer need it. Its a relatively small core that i just zipp tied it to the rad support and bumper, I think i still have some of the original connections that are provided to hold it in by peircing big zipties through your rad. Its a sandwich plate style cooler, so just thread adaptor onto your old oil filter pitch after you put the sandwich plate in place. Then just use basic rubber line to run to the oil cooler *where ever you may mount it.* Very simple intallation, very effective. Pictures *sorry its covered in oil because i didnt let the lines and cooler drain properly over night* Sandwich plate ![]() ![]() cooler ![]() asking $35CND +shipping. The lines on the cooler right now are still "ok", but could use replacement. Willing to meet buyers in Western Michigan *Detroit area*, and Windsor to Toronto. EDIT: Willing to except trades. Im looking for drivers side window switch and bezel, Shifter surround, radio surround, rear speaker grills for a HB all unpainted. This post has been edited by Valo666: Mar 9, 2008 - 9:03 PM |
Valo666 FS: Gauges and Oil Cooler Mar 9, 2008 - 5:20 PM
mikecelica Would the oil cooler work with 7afe? I can offer ... Mar 9, 2008 - 9:32 PM
DEATH I have all the bezils and whatnot that you are ask... Mar 10, 2008 - 9:37 AM
Valo666 QUOTE(mikecelica @ Mar 9, 2008 - 9:3... Mar 10, 2008 - 4:43 PM
DEATH QUOTE(Valo666 @ Mar 10, 2008 - 4:43 ... Mar 10, 2008 - 4:53 PM
mikecelica Can you find out if FOR SURE it will fit a 7afe. H... Mar 10, 2008 - 5:08 PM
Valo666 QUOTE(DEATH @ Mar 10, 2008 - 4:53 PM... Mar 10, 2008 - 5:48 PM
Valo666 bump...would perfer to sell for $. And yes th... Apr 1, 2008 - 6:26 PM
Valo666 bump...gauges sold with sending unit. Lotek pod up... Apr 6, 2008 - 6:40 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 12th, 2026 - 9:06 AM |
