Mar 12, 2008 - 4:29 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
I have a 2004 Rav 4 headunit that I want to install into my 4 speaker system. What will I need to make it work. Should I pick up an amp from a stock celi or should I see if the Ravs came stock with an amp and use that?
Sorry, sound systems are not my thing. -------------------- |
Mar 12, 2008 - 4:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
do u have the wire harness??u should check if this radio has a built in amp or not,it should...does it fit"???
-------------------- BANNED. for life, you moron.
Mar 12, 2008 - 8:48 PM
QUOTE(Harold_Fastwaker @ Mar 12, 2008 - 5:29 PM) [snapback]652773[/snapback] I have a 2004 Rav 4 headunit that I want to install into my 4 speaker system. What will I need to make it work. Should I pick up an amp from a stock celi or should I see if the Ravs came stock with an amp and use that? Sorry, sound systems are not my thing. how does it look from the back? Depends if whether 15 pin or 20 pin. If 20 pin, you need same year amp or create a hybrid harness. Now IIRC the 2004 rav 4 may measure 7.4 inches across, our units are 7 inches accross, you may have to modify you bezel like this ![]() or ![]() if neither, then its an amplfied system, you dont need amp, its plug and play, except for the measures.. post some pics. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
| Lo-Fi Version | Time is now: August 4th, 2026 - 9:15 AM |
