Mar 16, 2008 - 8:42 PM
This will fit the following convertible models:
1995-2003 Chevrolet Cavalier (has the proper plug) 1995-2003Pontiac Sunfire (has the proper plug) 1995-2000 Toyota Celica (may have to swap plug or splice wires) 1995 &UP Mitsubishi Eclipse and Talon (may have to swap plug or splice wires) 1995-1998 Saab 900 (may have to swap plug or splice wires) All of these cars use the same motors which are manufactered by Globe. The Toyota, Mitsubishi and Saab may use a different plug. found it on ebay, the pic looks true.. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 11, 2008 - 10:58 AM
Enthusiast ![]() ![]() Joined Sep 13, '05 From Kansas Currently Offline Reputation: 9 (100%) |
This will fit the following convertible models: 1995-2003 Chevrolet Cavalier (has the proper plug) 1995-2003Pontiac Sunfire (has the proper plug) 1995-2000 Toyota Celica (may have to swap plug or splice wires) 1995 &UP Mitsubishi Eclipse and Talon (may have to swap plug or splice wires) 1995-1998 Saab 900 (may have to swap plug or splice wires) All of these cars use the same motors which are manufactered by Globe. The Toyota, Mitsubishi and Saab may use a different plug. found it on ebay, the pic looks true.. do you know if any other cars have a quarter window motor or the brand? |
Sep 12, 2008 - 7:45 AM
what do youmean?
are you looking for the motor? why. Sometimes all you need to do is replace the pin if the motor not working. Or you looking to replace window? -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 12, 2008 - 9:25 AM
what do youmean? are you looking for the motor? why. Sometimes all you need to do is replace the pin if the motor not working. Or you looking to replace window? i just had the teflon roller replaced the window is having trouble going up. Im assuming its either a weak motor or its the switch. |
Sep 12, 2008 - 9:33 AM
what do youmean? are you looking for the motor? why. Sometimes all you need to do is replace the pin if the motor not working. Or you looking to replace window? i just had the teflon roller replaced the window is having trouble going up. Im assuming its either a weak motor or its the switch. Let me also clarify the window goes down fine.(with the motor) but when i try to raise it i get no response. no clicking sound nada. The window backplate is brandnew as well as the little teflon pins |
Sep 12, 2008 - 10:16 AM
it might be the motor, have you tried playing with the motor itself. when the window backplate was isntalled did you lubricate the tracks.
When i did my window, i cleaned it and lubricated it as much as i could. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 14, 2008 - 12:25 PM
it might be the motor, have you tried playing with the motor itself. when the window backplate was isntalled did you lubricate the tracks. When i did my window, i cleaned it and lubricated it as much as i could. hard to find convertible parts in this area of the country. can find just about anything else though. there is a pristene 94 es300 i will continue to pick from as you make mods from it |
| Lo-Fi Version | Time is now: August 11th, 2026 - 11:25 AM |
