Mar 16, 2008 - 11:08 PM
Enthusiast ![]() Joined Jun 24, '06 From Houston.TX Currently Offline Reputation: 0 (0%) |
I need a new clucth and i was wondering what performance clucth should i get. What would u guys recommend me
Mar 17, 2008 - 10:58 AM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
A stock one for the simple reason it is the cheapest and easiest thing to replace in the drive train. certainly nothing more than a Stage 1 or 1st step up from stock. I learned this the hard way years ago. If you beef up the clutch, the next weakest link is the axles or the transaxle itself. If you are driving really hard and something has to give, better the clutch slips a little than a broken CV or worse.
Put a heavy-duty racing clutch in my old 64 Falcon Sprint V8 4 speed, kid I sold it to proceeded to grab 2nd gear real hard during a drag race, ripped 7 teeth off a 9" limited slip ring gear, (but the clutch didn't slip!) I still didn't learn, put one in my 67 Mustang fastback with a later model 302 4 speed, also had a 9" limited slip. guy that bought it broke the transmission in half the 1st night he had it. had about 200 ft of rubber on the street in front of his house, banged 2nd gear, another few feet of rubber and then all kinds of marks in the road where the trans case tailshaft broke and the driveshaft beat hell out of the road and the bottom of the car, (but again, the clutch didn't slip!) The Mustang would run mid to low 13's in the 1/4 mile, not bad for 2 valve heads, carburetor and breaker point ignition,,, Just not worth it for a street driven car IMHO. The heavier ones also are more of a pain in traffic with the heavier pedal pressures, Maybe a Centerforce stage 1 pressure plate and disk if they have one to fit,,, |
Mar 17, 2008 - 12:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
QUOTE broke the transmission in half the 1st night he had it. had about 200 ft of rubber on the street in front of his house, banged 2nd gear, another few feet of rubber and then all kinds of marks in the road where the trans case tailshaft broke and the driveshaft beat hell out of the road and the bottom of the car Have you learned to stop selling cars yet? -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 18, 2008 - 11:26 PM
I was thinking of getting a stage 2 act clucth would that be good or bad
Mar 18, 2008 - 11:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
I would suggest a stock clutch. Esp if you are running a stock engine setup. I decided to go with a stock clutch for my V6 setup after reading about all the people who have reported issues with aftermarket ones. Rattling, breaking parts, pucks etc etc etc. Why go to that trouble when you could have a nice, quiet, reliable, stock clutch?
-------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Mar 20, 2008 - 1:55 AM
Enthusiast Joined Feb 21, '08 From york pa Currently Offline Reputation: 0 (0%) |
i say bullsh
Mar 20, 2008 - 9:54 AM
QUOTE(revski @ Mar 20, 2008 - 1:55 AM) [snapback]655899[/snapback] i say bullsh ...And why do you like this? -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Mar 20, 2008 - 4:01 PM
Enthusiast ![]() Joined Feb 4, '07 From Ontario, Canada Currently Offline Reputation: 0 (0%) |
I asked the same question and ended up deciding on an Exedy OEM clutch. I'm putting it in this weekend, so I'll let you know what I think. I've never felt this thing with a new clutch in it!
I considered Exedy Stage 1 or ACT SM00 (I think) basically their stage 1. For the added cost, I couldn't justify it. Unless you're making 250HP crank, I can't see the need for it. As revski says, you'll end up with wheel hop when your wheel-to-road torque capacity is less than your clutch disc's. |
Mar 21, 2008 - 6:44 AM
Enthusiast ![]() Joined Feb 4, '08 From UK Currently Offline Reputation: 0 (0%) |
QUOTE(mr-belowaverage @ Mar 20, 2008 - 4:01 PM) [snapback]656102[/snapback] I asked the same question and ended up deciding on an Exedy OEM clutch. I'm putting it in this weekend, so I'll let you know what I think. I've never felt this thing with a new clutch in it! I considered Exedy Stage 1 or ACT SM00 (I think) basically their stage 1. For the added cost, I couldn't justify it. Unless you're making 250HP crank, I can't see the need for it. As revski says, you'll end up with wheel hop when your wheel-to-road torque capacity is less than your clutch disc's. What engine do you have? I have the 3SGE and Exedy don't make a clutch for this engine! Although Ebay will tell you different - DON'T get a clutch of Ebay!!!!!!!!!!!! -------------------- ![]() |
Mar 23, 2008 - 4:38 PM
QUOTE(94TRDcelica @ Mar 21, 2008 - 11:44 AM) [snapback]656377[/snapback] What engine do you have? I have the 3SGE and Exedy don't make a clutch for this engine! Although Ebay will tell you different - DON'T get a clutch of Ebay!!!!!!!!!!!! I have a 7afe, but I'm pretty sure Exedy makes all the OE celica clutches. Also, most of the 4 cylinder clutches are exactly the same part. Exedy KTY18 I think is the part number for the 1.8L engines, and KTY11 for the 2.0L engines. For Stage 1 products, part 16800 fits the 1.8L engines, and 16803 fits the 2.0L engines, including the 3sge. |
Apr 7, 2008 - 6:49 PM
does anybody know a website for act clucthes i saw a link here once but i cant find it
Apr 7, 2008 - 6:51 PM
I don't know about for those clutches, but Dr. Tweak is an authorized retailer for some really excellent performance clutches...
You should PM him or go to his site, phoenixtuning.com. -------------------- ![]() |
Jun 16, 2008 - 3:52 PM
hey...im a DD and i was wonderin wat stage clutch would be better for me.....
thanks! |
Jun 16, 2008 - 4:38 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
I'll say this - I've used ACT clutches my entire life as a tuner and I've not had one bad experience just hella grab reliably - always.
Knock on wood -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Jun 16, 2008 - 6:45 PM
what kind a stage 2 or what cause i dont know nothing about clutches
Jun 16, 2008 - 7:52 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Here you guys go: http://www.phoenixtuning.com/zenstore/inde...amp;cPath=1_5_6
Pick out whatever you want, free shipping on all clutch kits The descriptions on the listings give a pretty good idea of what each one does. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jun 16, 2008 - 8:05 PM
avoid spec like the plague btw, i hear of alot of spec clutch failures...an unreasonably high amount. they had a batch of stage one clutches out with bad rivets for a while, but i hear of other things failing and breaking on them often.
Jun 17, 2008 - 11:18 AM
Enthusiast ![]() ![]() ![]() Joined May 10, '07 From Lubbock, Texas Currently Offline Reputation: 2 (100%) |
wheel hop? can u wheel hop with stock?.........when ever i race switchin from 1st to 2nd i do a burnout in motion i always redline...my last was against a mazda6 5speed 3.0 (Private road race not illegal) i took off on him leaving him then he cought up and beat me by a car and a half he said if it wasnt for his 3rd gear i would of beat him i bought the car as is cept short air...i have great take off but my overall speed is not all that...do u think the kid who had it b4 me staged it?...it used to be faster with my low profile tires on 16 rims..(had a blow out)
-------------------- ![]() feedback feedback If I buy or sale please leave me feedback...thanks cheap, quick, reliable, pick two I treat my 6gc better then my own woman |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 5:06 AM |
