> WTF my car shakes at 60mph!!!!
post Mar 17, 2008 - 10:30 PM
mrgrape
Joined Jun 21, '07
From SoCal
k so recently i put my car up on the lift during auto tech in high school to
identify front and back suspension and check brakes
after that i rotated my tires and put the tires back on
accidently i torque wrenched one too much
after up on the lift, when i go to 60mph my car starts shaking like it does normally at 90MPH
so im like **** and only drivee 50 mph on freeway thus getting honked or stared at....
whats the problem????
is it b/c of tires or something else?
post Mar 17, 2008 - 11:15 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
Did any weights fall off your tires? maybe unbalanced tires?
Are you sure you tightened all of your lugnuts?
Maybe you have worn suspension parts and your tires are worn unevenly. Inspect your tires.
________
post Mar 18, 2008 - 12:35 AM
JasonX
Joined Oct 18, '07
From Orange County, CA
I used to experience the same problem, because I always bought used tires, and never properly balanced. I also shaked about 60 and up. I can almost guarantee that it's something to do with balance and/or tires. I am not sure why you are shaking even at 90. Since my new tires, i don't shake at all.
post Mar 18, 2008 - 12:53 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
It is possible that there is a dynamic imbalance on your tires. You may have had a tire in the rear which was dynamically imbalanced to begin with, but you only noticed it at higher speeds because it was in the rear. Now that it is up front, you feel it earlier. If you're in auto tech, I'm sure they taught you the symptoms, causes and remedy for this.
post Mar 18, 2008 - 1:59 AM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
how do you accidentally over torque something like lug nuts? hand tighten then use a torque wrench, especially in a class they should have one..
i would start by putting the wheels on a balancing machine.
if your car is automatic, it could be your transmission, may want to get a new one of them while you're at it. shifting into reverse goin 60 on a highway may have caused some damage.
also check your headliner as that may cause a car to shake violently above 88mph and warp the time space continuum sending you on a wild journey back to 1955 preventing your parents from meeting much like michael j fox and christopher lloyd. but its all good, you drive a celica so returning to 1985 and living happily ever after is all but guaranteed!
post Mar 18, 2008 - 11:18 AM
QUOTE(MaskedMan @ Mar 18, 2008 - 1:53 AM) [snapback]655012[/snapback]
yup, happened to me. Get them balanced....
post Mar 18, 2008 - 11:29 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I agree that it's HIGHLY likely that your tires are out of balance.
It could also be that your car is out of alignment, or you have a suspension issue, and your rear tires are wearing unevenly, like cupping or wearing on the inside. After rotating those to the front, your car would handle differently and possible vibrate heavily at higher speeds.
post Mar 18, 2008 - 11:58 AM
ILuvMyCelica95
Joined Dec 16, '02
You shouldn't be driving 90MPH ever.
I'm with everyone else sounds like a balance issue. Bring the car somewhere and have them balance their wheels. Not trying to be rude but if you don't know what you're doing with a car you should really read first and learn before you end up with a bigger problem.
post Mar 18, 2008 - 12:08 PM
mrgrape
Joined Jun 21, '07
From SoCal
k so at auto tech today
i re rotated the tires
and torqued the nuts with one click exactly
and then i took it down a road at 80mph instantly
NO SHAKING
thank u!!!!!!!!!!!!!!!!!!! for all the help !
post Mar 18, 2008 - 12:09 PM
Im having the same problem ...with brand new wheels that were just balanced and aligned. Unless the guy that mounted them didnt do a good job balancing.
post Mar 18, 2008 - 12:16 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(lagos @ Mar 18, 2008 - 12:09 PM) [snapback]655143[/snapback]
brand new wheels ? do you have hub centeric ring ? I had that problem with my 17s when I had them, then I got those rigns and the problem was gone. the second time this happend, the tech who did my balancing didn't do it properly so I got my money back from them as I went back the same day and complained to the owner
post Mar 18, 2008 - 12:33 PM
Yes, i have hub centric rings.
I guess it IS possible the tech didnt do the job right.
He did mention that my rear tie rods were looking like they need replacing, so I dont know if thats contributing to the problem or not as I was having some shaking before installing the new tires too (though it seems worse now).
Car is perfectly stable at 60mph... but once you got o 75ish and up the shaking starts.
post Mar 18, 2008 - 6:33 PM
GriffGirl
Joined Feb 7, '07
^ I think you should take it back and tell them about the shaking. It sounds to me like the wheels aren't balanced properly. If your rear tie rods were, well, less than perfect, wouldn't it cause suspension issues and uneven tire wear? I don't think it would cause shaking. That would be more of a front tie-rod or a control arm bushing? Not sure...
post Mar 18, 2008 - 7:17 PM
94TRDcelica
Joined Feb 4, '08
From UK
Unbalanced wheels, un tightened lug nuts, worn tires and check that if your wheel hubs are bigger than the axle hubs you have the right size Spigot rings installed!
If none of those work get it electronically aligned and camber adjusted!
Does the car pull? Or just vibrate? If it doesn't pull then probably won't be alignement of camber!
post Mar 19, 2008 - 1:17 AM
QUOTE(94TRDcelica @ Mar 18, 2008 - 8:17 PM) [snapback]655280[/snapback]
alignment was done at the same time as the wheels were mounted/balanced. the car doent pull at all, just shakes at higher speeds.
post Mar 19, 2008 - 8:33 AM
pull isn't really related to camber so much as TOE
camber helps with cornering when used correctly.
But have you checked for a bent rim? or your wheel bearings?
post Mar 19, 2008 - 9:33 AM
shaunrichard
Joined Mar 13, '08
From Seven Cities, SE Virginia
QUOTE(mrgrape @ Mar 18, 2008 - 12:08 PM) [snapback]655142[/snapback]
NO SHAKING
I realize that as far as you are concerned this issue is resolved, but by any chance do you have directional tires? And if so, how exactly did you rotate them? It may very well have been a balancing or uneven wear issue, but the same symptoms might occur from tires rolling in the wrong direction.
'97 GT Convertible - deep jewel green pearl w/tan top, 5 speed, 240,000 miles and counting Gave up the ghost - being resurrected by perkyshadow
Lo-Fi Version Time is now: May 26th, 2026 - 1:12 AM
