> ST205 Projector Lights, Where can i buy them
post Mar 18, 2008 - 4:44 PM
NZvengeance
Joined Mar 18, '08
From New Zealand
I am looking to buy some projector headlight for my ST205 just like the ones on tufy's and AUM Celica's cars
Also can these projector lights be fitted with HID? are they already HID?
I haven't had much luck finding information on them.
post Mar 18, 2008 - 5:02 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
toyotaworld.com
there are lots of ppl with them, i just got some from a member actually.
NZvengeance
Joined Mar 18, '08
From New Zealand
ok ignore where to get them from as i found a thread with the toyota part numbers so thats fine.
however i still need to know if i can just put HID into these or not?
EDIT: also who sells the HID kits for them. preferably an international brand so i can get parts easily from NZ or Australia
This post has been edited by NZvengeance: Mar 18, 2008 - 5:22 PM
post Mar 19, 2008 - 1:39 AM
joehernandez
Joined Aug 5, '06
From San Luis AZ
go to the buying selling section,, theres two guys in there:
one sells the hid kits
and the other sells the projectors (lewfx)
post Mar 19, 2008 - 1:53 AM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
hid works just fine =)
if you get them and have any questions pm away =)
as for hid bulbs... i secure them then try my best to realign them so the bright spot is just below and to the middle of the cutoff so the most amount of light hits the road... if you dont take this step... they appear maybe half as bright as most the light just gets reflected and absorbed inside the projector.
also look to get some hid white 194 led bulbs for the indicators. inverted led style i think looks good, not too bright. the 5 smt or matrix ones whatever also look good, but for my tastes are a bit too bright (they make the actual projector look dim when looking at them from above the cutoff)
post Mar 19, 2008 - 2:07 AM
NZvengeance
Joined Mar 18, '08
From New Zealand
ok im not going to be near my gt4 for a few days so i cant check what bulbs are needed for low beam, high beam and parker?
post Mar 19, 2008 - 4:03 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Non Projectors
Low-Beam: 9006 bulb
High-Beam: 9005 bulb
Projectors
Low-Beam: H1 bulb
Indicator: 194 bulb
post Mar 19, 2008 - 9:12 AM
ILuvMyCelica95
Joined Dec 16, '02
search search search search search search search search search search search search search search search search search search search search
The sticky with the info: http://www.6gc.net/forums/index.php?showtopic=27828
The thread in the sticky with the info: http://www.6gc.net/forums/index.php?showto...iring+connector
I'm not trying to be rude/mean but there are SO many threads on this that contain the information you are looking for.
This post has been edited by ILuvMyCelica95: Mar 19, 2008 - 9:21 AM
Lo-Fi Version Time is now: June 11th, 2026 - 10:15 AM
