Mar 20, 2008 - 8:28 AM
Enthusiast Joined Jan 3, '08 From USA Currently Offline Reputation: 0 (0%) |
I'm trying to determine if I need any special tools to replace the timing belt on my 7afe.
I did a little digging and found the pdf's for the tech manual & they show a special tool when you remove the belt. Is it really needed? EDIT: It's called "SST" & it is pictured for the crankshaft pulley removal. Is this just a pulley puller? END EDIT Also, I'm assuming I need to get a new belt & idler pulley, a new valve cover gasket, and a new water pump/gasket. Did I miss anything? I'm assuming Toyota parts are the way to go, right? Sorry for all the questions, but I'm new to Celicas. Thanks! This post has been edited by Brightside: Mar 20, 2008 - 9:30 AM |
Brightside Timing Belt Question Mar 20, 2008 - 8:28 AM
Jeunesse I think you also need a timing gun... Mar 20, 2008 - 10:29 AM
scothaniel For the pulley tool, a standard Harmonic Balancer ... Mar 20, 2008 - 11:15 AM
Brightside QUOTE(scothaniel @ Mar 20, 2008 - 11... Mar 20, 2008 - 1:43 PM
scothaniel Nope, timing is still distributor based (at least ... Mar 20, 2008 - 2:25 PM
Brightside How do I hold the crankshaft pulley still in order... Mar 24, 2008 - 7:51 AM
alltracman78 QUOTE(scothaniel @ Mar 20, 2008 - 2... Mar 31, 2008 - 12:53 PM
scothaniel Thats where the high torque impact comes in! Mar 24, 2008 - 10:38 AM
Brightside QUOTE(scothaniel @ Mar 24, 2008 - 10... Mar 31, 2008 - 7:41 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 28th, 2026 - 5:27 AM |
