> TURBO KIT COMPLETE?, I got this from another forum
post Mar 20, 2008 - 8:29 PM
6G96GT
Joined Jan 20, '08
From East Coast
CT 26 Turbo
3stge MAP 2 sensor
3stge Manifold
Toyota Supra Celica GTS MR2 OIL FILTER SANDWICH PLATE
Ultra 8 mm hipro spark plug wire set Toyota 5sfe celica
28x7x2.5 FMIC TURBO INTERCOOLER
TOYOTA SUPRA CT26 7M-GTE Turbocharger outlet Gasket
BOOST GAUGE 82 86 93 SUPRA MK2 MK3 MK4 TURBO CELICA
MR2 T3/T4 TURBO ADAPTER FLANGE - CT25 TO T3/T4
Fuel Pressure Regulator Blue Universal
6 SUPRA TURBO 440cc FUEL INJECTORS
TOYOTA CT26 Turbo Turbocharger Complete Gasket Set
Turbo BOV Blow off Valve + Adapter pipe 2.5" B
Toyota MR2 91 92 93 94 95 Turbo 3SGTE Walbro Fuel Pump
Anything else that will be needed????
Replies (1 - 5)
post Mar 20, 2008 - 8:34 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
QUOTE(6G96GT @ Mar 20, 2008 - 9:29 PM) [snapback]656175[/snapback]
CT 26 Turbo
3stge MAP 2 sensor
3stge Manifold
wasnt this the kit manny locked the fs thread on??
BOOST GETS YOU LAID!!!!
blckcelica95
Joined Nov 20, '03
From Derry, NH
QUOTE(6G96GT @ Mar 21, 2008 - 1:29 AM) [snapback]656175[/snapback]
CT 26 Turbo
3stge MAP 2 sensor
3stge Manifold
safc2 or emange ultimate to tune it with
im not sure about the injectors . you might need to get the rx7 one's that a lot of guys uare using including me .
wide band to tune with.
oil press gauge . is a must on 5sfte
custom oil line parts to feed turbo oil
and you dont need the adapter for the ct-26 to work
This post has been edited by blckcelica95: Mar 20, 2008 - 10:06 PM
Driving a 5SFTE and LOVIN IT!!!!!!
http://www.myspace.com/17psicelica <-- celica engine build pics
post Mar 20, 2008 - 9:47 PM
QUOTE(jesterwr217 @ Mar 20, 2008 - 9:34 PM) [snapback]656178[/snapback]
yup
http://www.6gc.net/forums/index.php?showtopic=56508&hl=
this guy posted and ran. IMO, don't go near it.
post Mar 20, 2008 - 10:03 PM
zCelicaDude
Joined Nov 20, '06
From Auckland, New Zealand
i dont get it.... did i miss something here?
he has at the top ct26 turbo,
yet down the list has a ct26 to t3/t4 adapter?
so why does he have a ct26 if he has a adapter which is suited for the t3t4 turbos....
post Mar 23, 2008 - 6:52 PM
6G96GT
Joined Jan 20, '08
From East Coast
ok, won't do it. I was going to maybe do some more research "maybe" if it had been a correct list. Anywayz.
Thanks!
Lo-Fi Version Time is now: August 23rd, 2026 - 8:02 PM
