Mar 22, 2008 - 8:01 PM
Enthusiast ![]() ![]() ![]() Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
What is this engine? I've just come across it and am interested. I like that it is NOT boosted, right?? I have a 96 GT with the 5SFE. How do I get the 3SGE? Is it a standard swap? What else do I need and exactly what is it again?? I know there is a Gen 3 with 173 hp? Please clue me in...
Mar 22, 2008 - 8:29 PM
![]() Enthusiast ![]() ![]() Joined Dec 21, '06 From New Zealand Currently Offline Reputation: 0 (0%) |
It's the JDM Celica engine...fitted in SSII/SSIII etc. There's the normal one with 173-177hp (depending on year as they changed it down at one point due to emissions) and then the newer red top 'beams' model with VVT and ?198?hp.
Mar 23, 2008 - 6:33 PM
Is it relatively inexpensive (under 2G's) to obtain? Will it work with my 1996 Celica GT (5sfe) without any modding or tranny swaps? Thanks!!
Mar 23, 2008 - 6:38 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
the beams is like 3 grand.
Mar 23, 2008 - 6:39 PM
![]() Enthusiast ![]() Joined Nov 20, '03 From Derry, NH Currently Offline Reputation: 2 (100%) |
QUOTE(6G96GT @ Mar 23, 2008 - 11:33 PM) [snapback]657080[/snapback] Is it relatively inexpensive (under 2G's) to obtain? Will it work with my 1996 Celica GT (5sfe) without any modding or tranny swaps? Thanks!! id say it possible but high unlikely, since your car is obdII i would think it would be in the 3g range . The tranny will work. -------------------- |
Mar 23, 2008 - 7:14 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
the tranny will work but you will most likely get another (better with LSD) tranny with it if it's a redtop out of a SS-III. just search 3sge on ebay and you should find one. they are pretty pricey considering you can get a 3rd gen 3sgte for about the same price which will have a higher Hp rating due to the turbo setup. if you want NA though the B.E.A.M.S. Redtop is the way to go.
Mar 24, 2008 - 2:09 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
![]() my 3S-GE (3rd gen) in my SS-II a bit of info has ACIS induction (changes the size of the intake runners from small to large, which improves high torque throughout rev range 'simular sound' to v-tech when high reving, but if you get bigger cams/ internal work you can keep the sound long cam degree and high lift, 2.0L, 16 valve, twin cam & gears, stock extrators, pretty good engine in my opinion 'obdII' what that on about? -------------------- |
Mar 24, 2008 - 3:01 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '08 From Christchurch New Zealand Currently Offline Reputation: 0 (0%) |
QUOTE(Rusty @ Mar 24, 2008 - 2:09 AM) [snapback]657225[/snapback] 'obdII' what that on about? I think it is "on board diagnostics" Plug into a computer or some reader and will give error codes. -------------------- ![]() 1994年 トヨタ 神々しい My Facebook My Bebo QUOTE (loll6g @ Nov 6, 2008 - 5:53 AM) automatics are for lazy ass drivers who jst want there car so that they can look cool |
Mar 24, 2008 - 9:51 AM
Enthusiast ![]() Joined Jul 22, '07 From alexandria, VA Currently Offline Reputation: 0 (0%) |
Yea the OBD-II is a bunch of exta sensors stuck on the engines after 1996 to make sure we dont mess with any of the emissions stuff here in the US. I guess you SS-II guys dont have any of that? they dont plug ya into a comptuer to see if you are running clean? 6G96GT i say if you dont have emssions testing in NH, you should go for it, the 2nd and 3rd gen have loads of potential for NA power and are a third the cost of a Beams But if you do have emissions inspection, just forget about it if youve got a '96. It will be more headache and money than its worth, trust me ive been researchin the swap for my car for months now. -------------------- OBD-II makes me a sad panda
Mar 24, 2008 - 10:25 AM
Enthusiast ![]() ![]() ![]() Joined Dec 20, '07 From Valkeakoski, Finland Currently Offline Reputation: 0 (0%) |
QUOTE(MercuryFree @ Mar 22, 2008 - 8:29 PM) [snapback]656874[/snapback] It's the JDM Celica engine...fitted in SSII/SSIII etc. There's the normal one with 173-177hp (depending on year as they changed it down at one point due to emissions) and then the newer red top 'beams' model with VVT and ?198?hp. Not 100% right, as there are also other countries than Japan and Usa. The 3S-GE was available on celicas every where else, just not in the states. -------------------- |
Mar 24, 2008 - 10:54 AM
QUOTE(crandsberry @ Mar 24, 2008 - 2:51 PM) [snapback]657268[/snapback] Yea the OBD-II is a bunch of exta sensors stuck on the engines after 1996 to make sure we dont mess with any of the emissions stuff here in the US. I guess you SS-II guys dont have any of that? they dont plug ya into a comptuer to see if you are running clean? 6G96GT i say if you dont have emssions testing in NH, you should go for it, the 2nd and 3rd gen have loads of potential for NA power and are a third the cost of a Beams But if you do have emissions inspection, just forget about it if youve got a '96. It will be more headache and money than its worth, trust me ive been researchin the swap for my car for months now. nh has "emission testing" well sort of . its really just a diagnistic check on the cars computer to make sure the arent any problems with the car but they do fail if the car has been messed with. UNLESS you know someone who dose inspections -------------------- |
Mar 25, 2008 - 6:06 PM
QUOTE(Rusty @ Mar 24, 2008 - 2:09 AM) [snapback]657225[/snapback] ![]() my 3S-GE (3rd gen) in my SS-II a bit of info has ACIS induction (changes the size of the intake runners from small to large, which improves high torque throughout rev range 'simular sound' to v-tech when high reving, but if you get bigger cams/ internal work you can keep the sound long cam degree and high lift, 2.0L, 16 valve, twin cam & gears, stock extrators, pretty good engine in my opinion 'obdII' what that on about? NICE!! |
Mar 25, 2008 - 9:50 PM
QUOTE(Rusty @ Mar 24, 2008 - 2:09 AM) [snapback]657225[/snapback] ![]() my 3S-GE (3rd gen) in my SS-II a bit of info has ACIS induction (changes the size of the intake runners from small to large, which improves high torque throughout rev range 'simular sound' to v-tech when high reving, but if you get bigger cams/ internal work you can keep the sound long cam degree and high lift, 2.0L, 16 valve, twin cam & gears, stock extrators, pretty good engine in my opinion 'obdII' what that on about? how do you change sparkplugs on that engine? you have to pull the upper intake manifold it looks like. -------------------- |
Mar 26, 2008 - 1:05 AM
lol thanks and thats an old picture..
this is slighty newer ![]() real easy to change spark plugs just remove starting at the bottom: sump, conrod, pins and pistons & then use a Rachet with 2x extensions and unscrew from the top, remember to replace pistons after changing spark plugs. -------------------- |
Mar 26, 2008 - 2:24 AM
QUOTE(Rusty @ Mar 26, 2008 - 1:05 AM) [snapback]658058[/snapback] lol thanks and thats an old picture.. this is slighty newer ![]() real easy to change spark plugs just remove starting at the bottom: sump, conrod, pins and pistons & then use a Rachet with 2x extensions and unscrew from the top, remember to replace pistons after changing spark plugs. HAHAHA Awesome, unfortunately i do not think many people on this forum will understand that -------------------- ![]() 1994年 トヨタ 神々しい My Facebook My Bebo QUOTE (loll6g @ Nov 6, 2008 - 5:53 AM) automatics are for lazy ass drivers who jst want there car so that they can look cool |
Mar 26, 2008 - 3:05 AM
thats an old picture of my 3S-GE, it durrrrty but I guess you can handle it. -------------------- |
Mar 26, 2008 - 11:43 AM
^^ and usually its the same guys wanting to do the 3S-GTE swap lol
Yeah to the 3S-GE -------------------- |
Mar 26, 2008 - 12:25 PM
I dont wanna swap, in 2 years Im planning to buy a GT4
Actually friend of mine is selling right now, but I dont have the cash :S -------------------- |
Mar 26, 2008 - 2:35 PM
I want that 3S-GE!! I found one with a 5 spd manual tranny, ECU, and uncut wiring harness. It's supposed to have 47K on it and comes with a 3 month warranty if professionally installed. It's $2,800.00 (that includes the shipping and handling). I'm ready for it but I really need to know if it will directly swap right into my 96 GT without any modifications to get it in. I absolutely DO NOT want a 3sgte at all. No offense to the guys that have em, I guess I'm just "cursed" with turbo engines or something cause I get nothing but sh*t when I have em.
This post has been edited by 6G96GT: Mar 26, 2008 - 2:36 PM |
Mar 26, 2008 - 3:11 PM
QUOTE(6G96GT @ Mar 26, 2008 - 7:35 PM) [snapback]658226[/snapback] I want that 3S-GE!! I found one with a 5 spd manual tranny, ECU, and uncut wiring harness. It's supposed to have 47K on it and comes with a 3 month warranty if professionally installed. It's $2,800.00 (that includes the shipping and handling). I'm ready for it but I really need to know if it will directly swap right into my 96 GT without any modifications to get it in. I absolutely DO NOT want a 3sgte at all. No offense to the guys that have em, I guess I'm just "cursed" with turbo engines or something cause I get nothing but sh*t when I have em. the motor drops right in but the harness has to be modifid. i think.,Things like the ingniter and so on need to be swapped. if you use the stock tranny you need a custom clutch 3s pressure plate, modifed clutch disc.for the s54 tranny. if you use the tranny that come with the 3s . you may need custom drive axles but im not sure about that one. -------------------- |
| Lo-Fi Version | Time is now: June 21st, 2026 - 12:05 PM |
