2 Pages V  < 1 2
> Please explain, 3SGE
post Mar 26, 2008 - 4:03 PM
scothaniel
Joined May 1, '03
From Michigan
I've bought 2 x 3rd gen 3SGE's in the past 3 years. First one came with complete harness, ecu, trans, brakes, suspension and part of the exhaust for $1000. 2nd one was a partial, no harness or ecu, no suspension or brakes. That was $250 shipped.
If you get a complete setup, installation is a snap. Ignitor, coil, map sensor, injectors - all the same as the 5SFE. The standard trans is the same as the S54 in the US GT Celicas, but with a different final drive ratio. It uses the same engine mounts as the 5SFE. The only issue is the RHD wiring harness, which needed some moving / extending to fit in the LHD car.
There's also a rare 3SGE setup with the e-series trans w/ limited slip and superstrut suspension. The trans is nice, but then your looking at the same headaches as the MR2 trans install. The superstrut suspension is awesome for road and hard track, but its EXPENSIVE to maintain. The control arm setup alone is around $1800.
This post has been edited by scothaniel: Mar 26, 2008 - 4:04 PM
Scott
West Michigan
post Mar 26, 2008 - 5:07 PM
6G96GT
Joined Jan 20, '08
From East Coast
thanks for the info!! That's good stuff to know. I've finally decided exactly what I want to do.
This post has been edited by 6G96GT: Mar 27, 2008 - 4:33 AM
post Mar 26, 2008 - 11:59 PM
Rusty
Joined Nov 5, '07
From New Zealand
post Mar 27, 2008 - 3:39 AM
Penkka
Joined Dec 20, '07
From Valkeakoski, Finland
QUOTE(scothaniel @ Mar 26, 2008 - 4:03 PM) [snapback]658277[/snapback]
Number one. There are tons of 3S-GE:s with LHD, I think theres actually more LHDs than RHD. Think about the world; there really are other countries than USA, Iraq and Japan.
Number two. I´ll give you one guess to fin out, who has the superstrut and it is now squeeking like a horny woman, so I guess its about to break down.
Thats all <3
320hp @ 6300rpm and 420Nm @ 3250rpm. yay!
My ST205 WRC buildthread
post Mar 27, 2008 - 4:32 AM
6G96GT
Joined Jan 20, '08
From East Coast
QUOTE(Rusty @ Mar 26, 2008 - 11:59 PM) [snapback]658464[/snapback]
You bastard smile.gif but soon enough i will have the same engine in my engine bay too.
post Mar 27, 2008 - 8:10 AM
blckcelica95
Joined Nov 20, '03
From Derry, NH
QUOTE(6G96GT @ Mar 27, 2008 - 9:32 AM) [snapback]658534[/snapback]
Driving a 5SFTE and LOVIN IT!!!!!!
http://www.myspace.com/17psicelica <-- celica engine build pics
post Mar 27, 2008 - 2:10 PM
crandsberry
Joined Jul 22, '07
From alexandria, VA
thank you penkka for bringing some LHD st202 representation to 6GC! i dont think enough people noticed that from ur engine pic. wink.gif
OBD-II makes me a sad panda
post Mar 27, 2008 - 2:17 PM
Kadett
Joined Mar 17, '05
From The Netherlands
QUOTE(crandsberry @ Mar 27, 2008 - 8:10 PM) [snapback]658707[/snapback]
I have a ST202 as well smile.gif Only with a bit of change's.
BTW I would swap to a E56 (the FWD E serie tranny) anyday if I could. Build in LSD and shorter first/second gear. Only downside for me would be to ditch the Tein setup because tein doesn't sell separate front legs. BTW the install wouldn't give any headaches at all, the shifter linkage is correct, you only need GT4 or GT SS shifter cables to make it work.
I'm in desperate need of a LSD. Cant stop spinning up to 3rd and sometimes 4th gear now frown.gif.
post Mar 27, 2008 - 5:43 PM
6G96GT
Joined Jan 20, '08
From East Coast
QUOTE(blckcelica95 @ Mar 27, 2008 - 8:10 AM) [snapback]658552[/snapback]
No Prob. I already called up the mechanic I want to handle the swap and he'll probably fit me in early in May.
post Mar 15, 2010 - 5:18 AM
raise
Joined Mar 10, '10
From Hawaii
Can the 3SGE BEAMS engine be used with an automatic transmission? Can you fit the auto transmission from the 5SFTE onto a redtop BEAMS 3SGE?
I'm asking because I like the idea of the extra horsepower but in all honesty, I'll never go back to manual for my daily driver.
post Mar 15, 2010 - 11:50 AM
Penkka
Joined Dec 20, '07
QUOTE (raise @ Mar 15, 2010 - 6:18 AM) *
Toyota Altezza RS200´s have the 210bhp beams and was available with tiptronic.
post Mar 16, 2010 - 12:02 AM
Rusty
Joined Nov 5, '07
From New Zealand
Yea you can run an auto on a redtop beams (they do come out with them) what auto tranny do you run atm?
post Mar 16, 2010 - 3:29 AM
manphibian
Joined Oct 13, '06
From UK
REEEEEAAAAAALLLLLLLLYYYYYYYYY don't think you'd be getting the best out of the beams with an auto. You need to rev the nuts off it to get the power. Swapping in a Beams with an auto setup is a waste of money imo.
post Mar 16, 2010 - 6:00 AM
raise
Joined Mar 10, '10
From Hawaii
QUOTE (Rusty @ Mar 16, 2010 - 1:02 AM) *
I have a stock automatic 1997 GT with the 5SFE. Just bought it last week and titled it this morning. I always wanted this car but I had relegated it to something I wouldn't buy since it was mostly impractical until now.
Yes I know it might seem a waste to many to want to continue to use an automatic transmission when considering an engine swap but I really like the body style of the 6'th gen Celica and I know I'll have to replace the engine at some point as it has over 139k on it already. I may as well continue the hobby/fun factor and replace it with something that has a bit more power but that doesn't mean I have to compromise on the convenience I want out of my daily driving vehicle.
I'd get more oomph and performance by tearing out the AC too but I'm not doing that either wink.gif
This post has been edited by raise: Mar 16, 2010 - 6:02 AM
post Mar 18, 2010 - 4:04 PM
6G96GT
Joined Jan 20, '08
From East Coast
You won't have to replace the engine anytime soon, I have 187K with just the head rebuilt (only did that from bad valve seals so I figured I would do the whole head since it was torn down anyway). My block runs STRONG with no leaks, clean oil every time I change it, and no smoke. My PSI is great and it run nice and smooth. If you treat it right, you shouldn't have to touch it until about 175K (and by then, prolly just valve seals).
This post has been edited by 6G96GT: Mar 18, 2010 - 4:05 PM
2 Pages V  < 1 2
Lo-Fi Version Time is now: September 5th, 2026 - 2:44 PM
