Mar 23, 2008 - 10:16 AM
Enthusiast ![]() ![]() Joined Jun 13, '07 From Whitby, ON, CAN Currently Offline Reputation: 6 (100%) |
Hey so i got a 5SFE from im guessing a JDM camry. The exhaust was different and the intake so i switched them. Ive got it back in the car no problem when i realize the oil pan from this one is different then mine. I took off the oil pan to possibly swap when i see that it has some big block attached to the bottom which turns when you turn the crank. Is this those balance shafts that ive heard about?
My old oil pan wont fit on around this mechanism.... is it possible to take out. The reason im concerned is because it looks as if my oil pan will rest on the crossmember when fully installed does anyone know anything about this??? Also the Plate that bolts to the bottom of the tranny so that you can access the flywheel to driveplate bolts will no longer fit around this new oil pan.... because its white metal can i cut it up a bit to fit it around the oil pan?? so that my flywheel can stayed covered? Finally it seemed that the oil pan just used FIPG for the seal am i correct in assuming so? This post has been edited by 94celigts: Mar 23, 2008 - 10:33 AM |
Mar 23, 2008 - 10:50 AM
sounds more like a solora/camry 5sfe. theres several iterations of the 5sfe through out its lifetime with some differences such as balance shafts. did you ask for a specific year or range of years of engine or just 'gimme a 5sfe'?
Mar 23, 2008 - 12:25 PM
i asked for a 5sfe that will go plug and play into my 94 celica gts... thats what he gave me... anyways. I cut the cover to fit so thats good now... i just am worried about the clearence on the cross member...
Mar 27, 2008 - 4:26 PM
Thanks for all the GREAT help guys....
Mar 27, 2008 - 4:30 PM
QUOTE(94celigts @ Mar 27, 2008 - 5:26 PM) [snapback]658773[/snapback] Thanks for all the GREAT help guys.... no one has replied cause noone has the correct info to say for sure, obviously. would you prefer someone guess and say: yup, dont worry about a thing, it'll all fit no problem, and such? -------------------- Former Team 5SFTE pro member ;)
Mar 27, 2008 - 4:40 PM
No... not at all but some of the people like yourself or others that may have viewed it and have greater knowledge of swaps could have left something like sorry ive never experienced it. I dunno just felt to me like everyone looked and not one person said much... anyways, update everything is in just waiting to go back home and plug everything else in and throw the new stuff in and on. It ended up fitting with the camry oil pan on with the balance shafts in? you just have to cut away at the transmission access plate to fit it in. Maybe ill get some pictures. So others might get some answers. Ill let everyone know.
Mar 27, 2008 - 6:51 PM
QUOTE(94celigts @ Mar 27, 2008 - 5:40 PM) [snapback]658782[/snapback] No... not at all but some of the people like yourself or others that may have viewed it and have greater knowledge of swaps could have left something like sorry ive never experienced it. I dunno just felt to me like everyone looked and not one person said much... anyways, update everything is in just waiting to go back home and plug everything else in and throw the new stuff in and on. It ended up fitting with the camry oil pan on with the balance shafts in? you just have to cut away at the transmission access plate to fit it in. Maybe ill get some pictures. So others might get some answers. Ill let everyone know. cool, good to hear it fit without a problem, i "thought" it would, but didnt want to say yes without knowing. pics would be great, and would prolly make for a good sticky for future posters. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: August 27th, 2026 - 12:47 PM |
