> Where is this grease from?
post Mar 23, 2008 - 7:23 PM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
Was looking under the car today, and noticed my front pass wheel was splattered with what appeared to be mud. Upon further inspection it turned out to be grease of some sort (petroleum based smell).
- 6gsillyca   Where is this grease from?   Mar 23, 2008 - 7:23 PM
- - lagos   That would be your axle. Get a new one or change ...   Mar 23, 2008 - 7:27 PM
- - trdproven   Change those CV Boots as soon as you can or you...   Mar 23, 2008 - 7:42 PM
- - stephen_lee   yeah. your gonna have to replace those boots soon ...   Mar 23, 2008 - 7:47 PM
- - rjbibeau   no need for any KY...just reach under and grab a h...   Mar 23, 2008 - 7:53 PM
- - alltracman78   Before you replace the boot, check the outer clamp...   Mar 23, 2008 - 8:10 PM
- - stephen_lee   yeah. just feel around that first valley and see i...   Mar 23, 2008 - 8:21 PM
- - 6gsillyca   I had a quick feel around the boot, but didn't...   Mar 23, 2008 - 8:49 PM
- - stephen_lee   it just happens.. i have a 94 i had to replace bot...   Mar 23, 2008 - 8:52 PM
- - 6gsillyca   I'm aware things break down over time, but it ...   Mar 23, 2008 - 9:00 PM
- - bizzerk   The cracks can be very small and can mostlly be se...   Mar 23, 2008 - 9:11 PM
- - hongkongnerdboy   change it mines like that right now, its clucking ...   Mar 23, 2008 - 9:34 PM
- - 6gsillyca   How do I change the boot/joint out? Is it a hard j...   Mar 23, 2008 - 9:55 PM
- - WannabeGT4   I wouldn't bother replacing the axle since you...   Mar 25, 2008 - 11:39 PM
- - 6gsillyca   I was most likely going to replace the entire axle...   Mar 26, 2008 - 12:27 AM
- - WannabeGT4   You can't just buy a new axle for this applica...   Mar 26, 2008 - 7:33 AM
- - DEATH   Also can't you get those replacement boots fro...   Mar 26, 2008 - 10:49 AM
- - playr158   QUOTE(alltracman78 @ Mar 23, 2008 - 9...   Mar 26, 2008 - 10:58 AM
- - 6gsillyca   Well I was wondering about the hybrid axle issue s...   Mar 26, 2008 - 10:59 AM
- - Bitter   unless the axle is making noise all you need to do...   Mar 26, 2008 - 8:31 PM
|- - 6gsillyca   QUOTE(Bitter @ Mar 26, 2008 - 7:31 P...   Mar 26, 2008 - 10:58 PM
|- - Bitter   QUOTE(6gsillyca @ Mar 26, 2008 - 10...   Mar 27, 2008 - 7:24 PM
- - joehernandez   my car does noise when i do a close turn,, does th...   Mar 27, 2008 - 12:58 AM
|- - parriehunter   QUOTE(joehernandez @ Mar 27, 2008 - 12...   Mar 27, 2008 - 1:02 AM
- - joehernandez   QUOTE(parriehunter @ Mar 27, 2008 - 1...   Mar 27, 2008 - 1:08 AM
|- - parriehunter   QUOTE(joehernandez @ Mar 27, 2008 - 1...   Mar 27, 2008 - 1:50 AM
- - joehernandez   thanks a lot,, im going to check them right now   Mar 27, 2008 - 1:57 AM
Lo-Fi Version Time is now: August 29th, 2026 - 4:31 PM
