> How to remove rear seats in a convertible, Looking for a route to run wires
post Mar 24, 2008 - 2:02 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
As title states I am wondering for a way to run wires from the trunk to the engine bay. I've looked and tugged but I can't seem to figure out how to remove the rear seats, or how I would run wires behind the rear 1/4 plastic.
In my 94 hatchback, the seats folded down and unbolted, and the rear 1/4 plastic came out, exposing the speakers...
post Mar 25, 2008 - 4:31 PM
this should go on interior.
to remove the seats.
1. lift the bottom seat. this is held by clips.
once you have this done there are twoways to access the upper seat. this is held in place by 4 bolts.
from the bottom which imo is way difficult.
from the top. there is a piece of plastic that is held by 4 push pins. take them out carefully. you dont want to break them. then the black vynil that is dirty (in convertibles, unleess you clean it) biggrin.gif carefully pry it aside you may also have to remove two plastic covers in each seatbelt, which are also held by clips. (it was so long ago, but you get the idea)
then you can see t bars that go across the vert. there aare 4 14mm bolts. they are tight. but once you get them out you are on your way.
this 2 horizontal bars are the reasons verts dont need rear strut bars. we have 2 wink.gif
post Mar 25, 2008 - 4:36 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(njccmd2002 @ Mar 25, 2008 - 5:31 PM) [snapback]657869[/snapback]
wholey schett!! thank you!!
The local crew has been wondering this for a while... (it was all for me) and we were going to break into it one of theese weekends and find out if i could use one or not, BC we're fabricating front struts for all of us.
This post has been edited by D-Man: Mar 25, 2008 - 4:39 PM
Damn D-Man - most impressive.
post Mar 25, 2008 - 4:44 PM
QUOTE(D-Man @ Mar 25, 2008 - 4:36 PM) [snapback]657874[/snapback]
yes there have been some discussions about that. verts are very sturdy in the back
Lo-Fi Version Time is now: September 23rd, 2026 - 5:04 PM
