> What to torque it to?, 6 hexhead inner cv bolts
post Mar 24, 2008 - 9:24 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
EDIT:
Can someone please tell me what the 6 hexhead bolts should be torqued to? My manual lists:
hub nut - 137 ft-lbs
driveaxle inner cv joint-to-differential side gear shaft flange - 27 ft-lbs
right driveaxle centre bearing bracket bolts - 47
None of these seem correct, but since my axles are *non-stock* I'm not sure what the technical part term would be for them.
END EDIT
I need to replace my outer cv boot. I was looking into getting a new axle shaft, because I have read it is easier to RnR the whole axle rather than individual parts (axle, cv joint, cv boot etc). Then you also shouldn't need to worry about any damage to your joint because of the craked boot.
I need to know what parts to order though. Cv boot is on the front pass wheel. Would the axle half come with both inners and outers, and then would I need to RnR the inner with the e153 inner from my current set-up?
Would someone be able to explain what the inner and outer axles are, and how/where the inner attaches to the outer?
Here is a link to my thread in another sextion, but I thought the boosted guys might know the e153/st185 axles a bit better.
http://www.6gc.net/forums/index.php?showtopic=57022
This post has been edited by 6gsillyca: Apr 15, 2008 - 12:42 AM
- 6gsillyca   What to torque it to?   Mar 24, 2008 - 9:24 AM
- - phattyduck   Rebuilt ST185 front axles come as just the outers ...   Mar 24, 2008 - 2:19 PM
- - 6gsillyca   So a st185 axle will come with both inners and out...   Mar 24, 2008 - 7:23 PM
- - Silver94CelicaOwner   Yes, all you need to do is unbolt the six 8mm rece...   Mar 24, 2008 - 8:26 PM
|- - 6gsillyca   QUOTE(Silver94CelicaOwner @ Mar 24, 2008 ...   Mar 24, 2008 - 9:36 PM
- - Silver94CelicaOwner   Nope, it doesn't matter. Any Celica All-Tra...   Mar 25, 2008 - 10:36 AM
- - 6gsillyca   Ok thanks. I knew there were differences between t...   Mar 25, 2008 - 11:24 AM
- - phattyduck   Just so you are clear, the 'inner' axles a...   Mar 25, 2008 - 1:40 PM
- - 6gsillyca   Can someone confirm for me if st185 had the option...   Mar 26, 2008 - 12:22 AM
- - 6gsillyca   Will I need to repack the inner/outer/spacer secti...   Mar 26, 2008 - 11:04 AM
|- - phattyduck   QUOTE(6gsillyca @ Mar 26, 2008 - 9:0...   Mar 26, 2008 - 2:58 PM
- - scothaniel   Yes, there are ABS and non-ABS alltrac axles.   Mar 26, 2008 - 2:59 PM
|- - alltracman78   QUOTE(scothaniel @ Mar 26, 2008 - 2...   Mar 27, 2008 - 10:09 PM
- - 6gsillyca   So I was able to get out and have a look to see wh...   Apr 6, 2008 - 4:21 PM
- - 6gsillyca   Do I need to tuorqe these when I tighten them? How...   Apr 7, 2008 - 10:34 PM
- - 6gsillyca   Is my axle supposed to have the 3 "ridges...   Apr 8, 2008 - 11:43 AM
- - 6gsillyca   bump for torque spec   Apr 15, 2008 - 12:42 AM
- - alltracman78   48 lb/ft Make SURE you use BLUE thread lock too. T...   Apr 17, 2008 - 11:54 AM
- - alltracman78   Go to this thread, it explains how to get the tie ...   Apr 17, 2008 - 11:58 AM
- - 6gsillyca   It came with a cork gasket already installed. Will...   Apr 19, 2008 - 12:06 AM
- - Silver94CelicaOwner   Yea its an 8mm Hex, and I'll bet money on it. ...   Apr 19, 2008 - 3:44 AM
- - 6gsillyca   Thanks for all the info and pics. I was going to g...   Apr 19, 2008 - 12:07 PM
- - Silver94CelicaOwner   The stock CV bolts are 8mm. I didn't even...   Apr 19, 2008 - 5:24 PM
- - alltracman78   Alltrac axle bolts are 10mm, not 8mm. I can't ...   Apr 19, 2008 - 9:35 PM
- - 6gsillyca   When I got the axle it came with a zip-tie running...   Apr 19, 2008 - 11:25 PM
- - Silver94CelicaOwner   Pitman arm! Right. Thats the one...thanks Jere...   Apr 21, 2008 - 5:13 PM
- - 6gsillyca   Are those bolts normal length? The ones I took off...   Apr 21, 2008 - 11:40 PM
- - Silver94CelicaOwner   Yeah those are the stock bolts from an MR2 Turbo. ...   Apr 22, 2008 - 11:50 AM
- - alltracman78   I owe you an apology, the Alltrac bolts are also 8...   Apr 28, 2008 - 4:07 PM
- - Silver94CelicaOwner   It's all good man, no worries. 6gsilly...   Apr 29, 2008 - 12:10 PM
- - 6gsillyca   Well the last few weeks have been really sh!tt...   Apr 29, 2008 - 11:48 PM
Lo-Fi Version Time is now: August 27th, 2026 - 10:01 AM
