> Alarm Question
post Mar 27, 2008 - 9:14 AM
D-Man
Joined Jan 18, '08
From Houston
Okay, i've been searching and cant find anything to answer my question. I know this is probably a repost as i can see it being a common problem. Just point me to one of the links, but i cant find it using the search...
Deal is this: Bought the car, a month later the dude i bought it from, he found the remotes for the alarm. I believe it's factory... With the keyless entry and all. i found the prox sensor, but i cant find the "CPU" of the alarm. I need to find it so that i can re-program the remotes. ANyone know where it is? And how to get to it? Pics would be great!!
Damn D-Man - most impressive.
Replies (1 - 19)
post Mar 27, 2008 - 9:41 AM
azian_advanced
Joined Apr 18, '05
From Calgary
did you try looking under the seat?
post Mar 27, 2008 - 9:58 AM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(azian_advanced @ Mar 27, 2008 - 10:41 AM) [snapback]658588[/snapback]
I've removed the seats (durring an unrelated event) and it's all carpet...
I can tell that it must be under my dash somewhere, that's where the shock sensor is located. But i cant trace down the wires...
This post has been edited by D-Man: Mar 27, 2008 - 9:59 AM
post Mar 27, 2008 - 12:20 PM
lubu
Joined Apr 2, '07
From Great Western Plateau
Mine is on top of the ECU and the ECU is located underneath the center dash.
98% completion
aaRon
post Mar 27, 2008 - 12:23 PM
D-Man
Joined Jan 18, '08
From Houston
Maybe... Did it have a reset button on it?
post Mar 27, 2008 - 12:32 PM
lubu
Joined Apr 2, '07
QUOTE(D-Man @ Mar 28, 2008 - 1:23 AM) [snapback]658675[/snapback]
Cant remember, I was installing new alarm thats why I pulled it out...it might have a small hole where you poke a nail in, to reset or something but im not entirely sure...
98% completion
aaRon
post Mar 27, 2008 - 1:08 PM
D-Man
Joined Jan 18, '08
From Houston
post Mar 27, 2008 - 1:47 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(D-Man @ Mar 27, 2008 - 1:08 PM) [snapback]658691[/snapback]
Shouldn't have to unless they are new ones or different ones. it's possible the alram just needs to be reset or it's turned off currently. I can call my guy at Toyota and he can walk you through the diagnostics of it.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Mar 27, 2008 - 6:23 PM
lubu
Joined Apr 2, '07
QUOTE(DEATH @ Mar 28, 2008 - 2:47 AM) [snapback]658700[/snapback]
You are correct. When I open up the remote control I can see a removable IC which I think was tuned to a specific frequency that matches witht the alarm ECU. Maybe you need to finid out which frequecy ur ECU is tuned to and retune the IC or get a replacement or something. The hole on the ECU is probably just for resetting the ECU ifself, not retuning.
98% completion
aaRon
post Mar 27, 2008 - 8:11 PM
pabel89
Joined Sep 28, '07
From new jersey
when i programed my factory keyless remote, mines was under the driver seat. but i also heard it can be under the glove compartment. and yes thier a reset bottom and its easy to install if you find it. all you have to do is hit the remote buttom and the reset bottom hold it for 5 sec and your done.
post Mar 28, 2008 - 12:35 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(pabel89 @ Mar 27, 2008 - 9:11 PM) [snapback]658895[/snapback]
yeah, every remote i've ever programed was like that. i figured it'd be the same way. Thats why i wanna find the "ecu" of the alarm. The lights usually do some lighting up to show that it's synced.
Well, atleast i'd like to try. shouldn't be that hard...
post Mar 28, 2008 - 1:46 PM
azian_advanced
Joined Apr 18, '05
From Calgary
so you haven't found it yet? if it's not beneath the seat, behind the glove compartment or above the ECU, then it must be tucked high up behind the driver-side panels right next to the steering column..
that's usually where most installers would keep them..
This post has been edited by azian_advanced: Mar 28, 2008 - 1:47 PM
post Mar 28, 2008 - 2:13 PM
D-Man
Joined Jan 18, '08
From Houston
Woah, i havn't checked yet... I gotta pull off some panels and do some serious 69ing with my driver side of the car to get up there... I gotta wait till i have day time to see what the hell is going on in there, HOPEFULLY tomorrow.
Hopefuly i can paint that fender too...
post Mar 28, 2008 - 2:24 PM
pabel89
Joined Sep 28, '07
From new jersey
maybe your car doesnt have one. calll the toyota and give them your vin# see if your car had a keyless entry.
post Mar 28, 2008 - 2:35 PM
D-Man
Joined Jan 18, '08
From Houston
it does, i have the clickers, i have the shock sensor, i have it all. I have to set the alarm by poping the hood when the car is off, closing it, and waiting 45 sec...
post Mar 28, 2008 - 3:00 PM
DEATH
Joined Dec 19, '07
From tx
My last car's alram ECU was mounted between the steering column and the center console - it's not at all hard to get to and like I said my friend at Toyota will walk you through it over the phone.
EXT: WRC/TRD/404
post Mar 28, 2008 - 3:02 PM
pabel89
Joined Sep 28, '07
From new jersey
call the toyota give them your vin # and see if they tell you where it was located on your car.
post Mar 28, 2008 - 3:06 PM
D-Man
Joined Jan 18, '08
From Houston
i could probably find it if i ever had DAY time to work. that's just the prob though, no place, no light, no nothing.
So i was asking so that i could find it at night, the only safe time to work on my car in my apps. Well, you gotta worry about the "thugs" and "Ganksters" and everyone else that listens to rap music... but they can't evict me from my appts so i'm not really worried about them.
post Mar 28, 2008 - 3:08 PM
pabel89
Joined Sep 28, '07
From new jersey
why dont you buy an after market alarm?
post Mar 28, 2008 - 3:12 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(pabel89 @ Mar 28, 2008 - 4:08 PM) [snapback]659203[/snapback]
because i have one installed already.
Besides, i can upgrade features. but all i gotta do is push 2 buttons simotaniously, or i can RE INSTALL the entire damn thing.
if i cant find a button, what makes you think i would be able to find all the wires?
Why would i want a new one?
Lo-Fi Version Time is now: July 11th, 2026 - 11:24 PM
