> 3vzfe
post Mar 29, 2008 - 2:08 AM
Kerr1
Joined Dec 24, '06
From jonesville
these v6 camry motors fit out cars dont they? i believe i remember som1 on here doing it b4...but i cant remember if it was a 1mzfe or not
post Mar 29, 2008 - 11:22 AM
alltracman78
Joined Aug 9, '06
From Ma
The 3VZ is the older Camry V6 with the cast iron block.
I would guess that it would still fit in your Celica, but IMO you're better off with the 1MZFE or 3MZFE [3.3]. Both are aluminum block.
post Mar 30, 2008 - 12:48 AM
Kerr1
Joined Dec 24, '06
From jonesville
i found a whole car w/ 1mzfe in it...would this b enough to do the swap w/ or will there b other parts i have to get?
post Mar 30, 2008 - 3:37 PM
alltracman78
Joined Aug 9, '06
From Ma
That should cover most parts, but you might need some other stuff, depending which vehicle it is.
Also, depending which year, and if it's an auto [most likely] the ECU might not like being put in a manual trans vehicle and might throw some codes. All depends on the year and vehicle.
I made a mistake BTW, the 3VZ is the truck V6 [still cast iron, but it's the 3.4, not the 3.0], the older V6 is the 1VZ.
post Mar 30, 2008 - 4:39 PM
Kerr1
Joined Dec 24, '06
From jonesville
gotcha...i saw where they make trd supercharges for the 1mzfe...so thatll prolly b tha way i go...do you know if you can make a good amount of power from them w/o tearing the motor apart and changing internals? that is w/ good tuning
Lo-Fi Version Time is now: August 30th, 2026 - 1:33 AM
