> bogging at 5k then goes to 7k?, 3rd gen 3sgte
post Mar 30, 2008 - 12:40 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well i just the new warblo fuel pump and though i solve the boggin problem but then last night i finally took the car out for a full throttle ride..as u know it i free rev the motor to 7500k and it was fine.. took the car out for a full ride on the road as i was gunning it in 2nd gear the car bogged at 5k then went to 7500..did it in third too didnt want to try it any higher gears..anyone have a clue what is going on. i have the 2 bar map boosting only 8psi running everything stock full now till i figure out this problem.
Here is the link to the video:
http://s52.photobucket.com/albums/g22/miss...nt=MOV02577.flv
This post has been edited by RUNNIN-LOW: Mar 30, 2008 - 1:38 PM
- RUNNIN-LOW   bogging at 5k then goes to 7k?   Mar 30, 2008 - 12:40 PM
- - lagos   How old are your plugs,wires, cap and rotor? Does...   Mar 30, 2008 - 5:06 PM
|- - phattyduck   QUOTE(lagos @ Mar 30, 2008 - 3:06 PM...   Mar 30, 2008 - 10:46 PM
- - RUNNIN-LOW   well im not really sure ive posted it on the gt4 f...   Mar 30, 2008 - 8:10 PM
- - lagos   where did you get your map sensor from? did it com...   Mar 30, 2008 - 8:47 PM
- - RUNNIN-LOW   the cap,rotors and coil pack are brand new and the...   Mar 31, 2008 - 11:01 AM
|- - phattyduck   QUOTE(RUNNIN-LOW @ Mar 31, 2008 - 9...   Mar 31, 2008 - 1:07 PM
- - lagos   check the ecu for codes.   Mar 31, 2008 - 12:21 PM
- - RUNNIN-LOW   no codes come up at all and ill check the mr2 foru...   Mar 31, 2008 - 1:39 PM
|- - toyotacrazy   QUOTE(RUNNIN-LOW @ Mar 31, 2008 - 1...   Mar 31, 2008 - 7:11 PM
- - Driveby   Like the guys say, sounds like an ignition fault t...   Apr 2, 2008 - 4:13 PM
- - RUNNIN-LOW   ok well i have been running ngk cold plugs with th...   Apr 2, 2008 - 7:06 PM
- - RUNNIN-LOW   alright well its personal now..the car still boggs...   Apr 8, 2008 - 10:30 PM
- - lagos   Huh? Why would you take apart your intake manifold...   Apr 8, 2008 - 10:35 PM
- - RUNNIN-LOW   ooh meaning by intake manifold is just checking th...   Apr 13, 2008 - 9:31 PM
- - lagos   QUOTEthe map sensor is from a 2nd gen mr2 Thats y...   Apr 13, 2008 - 9:48 PM
- - jazzcornet   the 94 map sensor is not for the genIII. make sure...   Apr 23, 2008 - 10:35 PM
|- - phattyduck   QUOTE(jazzcornet @ Apr 23, 2008 - 8...   Apr 25, 2008 - 1:08 PM
- - rjbibeau   bingo   Apr 24, 2008 - 4:52 PM
- - jazzcornet   QUOTE(jazzcornet)the 94 map sensor is not for the ...   Apr 25, 2008 - 1:28 PM
- - RUNNIN-LOW   thanks guys yeah the one i have on righ tnow is li...   Apr 27, 2008 - 5:19 PM
Lo-Fi Version Time is now: August 27th, 2026 - 9:03 PM
