Apr 6, 2008 - 4:37 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
I have a 93 3sgte (from an sw20) and therefore my ign wires have the clips (as opposed to the plunger style). I orered a tune up set from ats for 93 mr2 and the coil wire I got its a few inches too short compared to the one that is coming off the car. Is there a difference between the coil wire for a mr2 3sgte and a gt4 3sgte? I suspect that on an mr2 the ignitor is mounted closed to the dizzy and would require a shorter wire.
Is there a P/N for just the coil wire? Does anyone know what coil wire I would need to be using? Are the P/N different for 93 mr2 and 93 gt4? |
6gsillyca 2 gen 3sgte coil wire Apr 6, 2008 - 4:37 PM
WannabeGT4 92-93 All-Trac Coil Wire:
19590-74150
$9.08 f... Apr 6, 2008 - 9:13 PM
jgreening That coil wire has never been replaced since the s... Apr 6, 2008 - 10:22 PM
6gsillyca QUOTE(jgreening @ Apr 6, 2008 - 9:22... Apr 6, 2008 - 11:42 PM
WannabeGT4 Dunno about that. I use the Toyota EPC to find my ... Apr 7, 2008 - 9:10 AM
lagos you normally just look up celica or mr2, and then ... Apr 7, 2008 - 2:05 PM
6gsillyca QUOTE(lagos @ Apr 7, 2008 - 1:05 PM)... Apr 8, 2008 - 11:59 AM
6gsillyca So I got my shipment from 1sttoyotaparts with my c... Apr 23, 2008 - 10:27 PM
WannabeGT4 That's the wire I used and it fits fine with t... Apr 24, 2008 - 2:15 AM
6gsillyca Not sure how it is mounted from the factory, but m... Apr 24, 2008 - 2:18 AM
WannabeGT4 QUOTE(6gsillyca @ Apr 24, 2008 - 2:1... Apr 24, 2008 - 2:21 AM
6gsillyca That is what I have read aswell, but was not able ... Apr 24, 2008 - 2:25 AM
WannabeGT4 QUOTE(6gsillyca @ Apr 24, 2008 - 2:2... Apr 24, 2008 - 2:37 AM
6gsillyca Your dizzy looks like it is mounted closer to the ... Apr 24, 2008 - 11:19 AM
DEATH From memory his stuff looks like MR2 parts whereas... Apr 24, 2008 - 11:27 AM
6gsillyca I would assume my parts are *mostly* mr2 parts, as... Apr 24, 2008 - 11:46 AM
DEATH Damnit on second look both of yours look like MR2 ... Apr 24, 2008 - 11:50 AM
WannabeGT4 My bracket is the stock 94-95 bracket for the igni... Apr 24, 2008 - 11:50 AM
6gsillyca Wannabe, your ignitor is also facing towards the f... Apr 24, 2008 - 1:47 PM
WannabeGT4 QUOTE(6gsillyca @ Apr 24, 2008 - 1:4... Apr 24, 2008 - 1:52 PM
6gsillyca Is your dist. in the stock location? It looks like... Apr 24, 2008 - 1:56 PM
WannabeGT4 QUOTE(6gsillyca @ Apr 24, 2008 - 1:5... Apr 24, 2008 - 1:59 PM
6gsillyca I thought it was the pic angle as well but your ig... Apr 24, 2008 - 2:12 PM
WannabeGT4 QUOTE(6gsillyca @ Apr 24, 2008 - 2:1... Apr 24, 2008 - 2:48 PM
DEATH Sorry it took me so long - I ended up having to wa... Apr 24, 2008 - 3:08 PM
6gsillyca Well I connected the dist end up and it looks like... Apr 24, 2008 - 3:19 PM
DEATH Mine is the one for the '93 altrac - got it fr... Apr 24, 2008 - 3:27 PM
6gsillyca Well a 92-93 alltrac is the P/N Wannabe supplied m... Apr 24, 2008 - 3:53 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 6:04 PM |
