> Turbo Help
post Sep 1, 2003 - 3:02 AM
Striking4
Joined Jul 26, '03
From St. George, Utah
I am in the middle of installing a custom turbo system on my 7A-FE engine. I have one small problem. The turbo I got from the yard has both water and oil cooling inlets and outlets for the housing. How do I tell which one is which?
post Sep 1, 2003 - 3:45 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
i dont think it matters, the liquid is only for cooling, unlike the oil.
btw where are you tapping into for the liquid cooling?
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 1, 2003 - 2:22 PM
SpedToe169
From Dallas, Tx
Ohhh yes, it does matter very much. If you got a turbo with an oil and water center section you have to make sure you get everything hooked up correctly because not only does the oil cool the turbo, it also lubricates the bearings. Its very unlikely that you got a ball bearing turbo so that means you have bearings that ride on oil. Oil is the only thing keeping the happily spinning parts of the turbo from coming into high speed destructive contact with the happily non-spinning parts. Thats why oiling is soooo important to a turbo.
I'm guessing you have a T3 or a T3 variant, if so the oil lines will have a fitting with a 2 bolt flange. The water lines won't have the flange. The water lines should also be bigger. The oil flange looks like this:
Ebay Flange
post Sep 2, 2003 - 12:54 AM
Striking4
Joined Jul 26, '03
Thanks. I now have them figured out. The oil I will be tapping from a T joint after my remote oil filter. The water I am not so sure about. I'm thinking of just tapping into the cool end of the radiator, but I am not sure. Any suggestions would be great.
post Sep 2, 2003 - 12:54 PM
I would think you have a water inlet and outlet.
post Sep 2, 2003 - 1:41 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
yea, to clarify, i didnt think that the direction of the water cooling made a difference. the oil lines have to run in a definate direction, from top to bottom and the oil feed is usually the smaller hole.
post Sep 4, 2003 - 12:15 AM
Striking4
Joined Jul 26, '03
Thanks for the help guys. The turbo should be in and all the plumbing done by next week.
post Sep 4, 2003 - 12:21 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
good luck with it.
i get my downpipe made on friday.
i started the car with a cheapo down pipe that i made my self and the car did not sound any different than from stock, which i kinda like
btw i had the pipe sorta flow into the stock exhaust and dont have my DR catback on yet, im sure it will sound very different on friday
This post has been edited by 97sccelica: Sep 4, 2003 - 12:26 AM
Lo-Fi Version Time is now: May 18th, 2026 - 1:08 AM
